Shackle Flip Kit - The Official Armor Tech Offroad Thread!
Discussion in 'Armor Tech Offroad' started by ArmorTech, Mar 6, 2013.
  1. Mar 18, 2013 at 8:15 PM
    #61
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    this is what i was talking about in more detail...12in shocks will work for me with what i want to do....my 10's will not
  2. Mar 18, 2013 at 8:17 PM
    #62
    jandrews
    '09 FourDubDee TRD OR
    You can always make a longer shock work by increasing bumpstop height...you'll lose some uptravel (possibly also some downtravel) that way, but hell, who knows, it might make your spring packs last longer...everything's a compromise...
    Also, regarding negative leafspring arch: I've yet to hear anything other than anecdotal word-of-mouth that it's a problem as long as you're within the elastic limits of the material the spring is made from. In other words: Unless you stretch the spring enough to deform it, it doesn't really matter. The last materials engineer who's brain I picked on the matter said, in not so many words:
    "Think about it this way...a coilspring doesn't get damaged from compression or extension unless you squash or pull it far enough to bend the metal itself. This applies to leaf springs or airplane fuselages or any material intended to stretch during use. Moving from elastic deformation to plastic deformation is the problem."
    He did note aggressively moving a spring through elastic cycles generates wear more quickly, as metal fatigue is basically a function of number of cycles.
    Boiled down version: Negative arch that doesn't deform your leaf spring won't damage it, but it will wear it out more quickly, thus leading to earlier breakage or sag.
    So, leaf springs are now a wear item. Welcome to offroading and modding, right?
  3. Mar 18, 2013 at 8:31 PM
    #63
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    What's the best way to remove the rivets from the stock hanger, grinder w cut-off wheel?
  4. Mar 18, 2013 at 8:32 PM
    #64
    hard2kill
    Rhinebeck NY
    well said man.....ive always felt this way about it....but everyone just repeats what someone else tells them...
  5. Mar 18, 2013 at 8:33 PM
    #65
    hard2kill
    Rhinebeck NY
    grinder and air chisel
  6. Mar 18, 2013 at 8:37 PM
    #66
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Dooo want
  7. Mar 18, 2013 at 10:43 PM
    #67
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    in cause I might need them LOL Do longer shackles allow for more droop/travel?
  8. Mar 19, 2013 at 4:38 AM
    #68
    jandrews
    If you don't know what they do, you should research until you do before messing with them.
    They affect many things within your suspension.
  9. Mar 19, 2013 at 6:02 AM
    #69
    hard2kill
    Rhinebeck NY
    ^^^^this....
  10. Mar 19, 2013 at 6:26 PM
    #70
    ArmorTech
    ArmorTech [OP] Well-Known Member
    Adam
    Thanks for your post, this information is already contained in the first post as well.
    All I will say is that a lot of the stock 05+ Tacomas that I have looked at have a factory setup that allows quite a lot of negative arch. Bottom line you're right, your entire truck is now a wear item, welcome to offroading.
    Grind the heads off, drill out the center and pound the heck out of them. An air chisel will help if you have access but drilling as much as possible without hitting the holes in the frame will help a lot. Be careful when punching out the lower rivets. The rear cross member is thin and will simply bend with the rivet still attached.
    Longer Shackles are used to add lift. They will have very little effect on the suspension travel.
  11. Mar 20, 2013 at 11:04 AM
    #71
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    That's why i asked the question....:tumbleweed:
  12. Mar 24, 2013 at 8:19 PM
    #72
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    There's a few long threads on here where people go back and forth and a lot is learned. If I wasn't on my phone I would give you some links. :)
  13. Mar 24, 2013 at 8:29 PM
    #73
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
  14. Mar 24, 2013 at 11:33 PM
    #74
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    Does this work on all pro standard pack or unknown at this time?
    Regarding the rivets, does it require a lot of grinding and pounding to get em out? Im just concerned about the noise factor doing it at home.
  15. Mar 25, 2013 at 10:03 AM
    #75
    ArmorTech
    Adam
    I have not tested the kit with those springs. As long as they are the same length as the factory springs you'll be fine.
    You have to cut the head off of a total of 8 rivets. Drilling out the middle of the rivet helps for removing them. Get as close to the middle as you can, drill as large as you can with out hitting the frame. If you hit the middle of the rivet perfectly you would barely need to hit them for them to pop out, but that is easier said than done.
  16. Mar 25, 2013 at 10:18 AM
    #76
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    Sub. Ill measure my alcans 6 inchers
  17. Mar 25, 2013 at 11:00 AM
    #77
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    That's putting it mildly... :eek:
    The rivets are a total PITA to remove - the drill out method is how I did it as well.
  18. Mar 25, 2013 at 11:08 AM
    #78
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    any idea when the OME kit gonna be released?
  19. Mar 25, 2013 at 12:34 PM
    #79
    mjm540ii
    Oxford, PA
    I'm just having trouble disconnecting my brake lines:mad: 10mm wrench won't easily break them loose and I don't wanna strip 'em. Ideas welcome..
  20. Mar 25, 2013 at 12:38 PM
    #80
    dirtymike
    dirtymike Well-Known Member
    mike
    orlando fl
    2nd gen
    Fiberglass,spindles, coils, 4"leafs, gears&locker, no skids :-/
    Get a wrench made for brake lines I believe its called a flare nut wrench
    dreadedyota likes this.
