Shackle Flips and U-Bolt Flips Info Needed
Discussion in 'Suspension' started by viperstd, May 18, 2011.
  1. May 19, 2011 at 6:49 AM
    viperstd
    viperstd [OP] Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    Right on. Thanks for the update.
    Can you comment on the effects of a shackle flip on daily driving and offroad on steep descents?
    When offroading is there a concern of "them opening up" like revolvers and then getting jammed (inverted) against the frame?
    How much lift are we looking at for the new design? (I'm trying to avoid more lift at the moment since I'm worried about trailering and rake angles).
    Cheers Kevin!
  2. May 19, 2011 at 1:32 PM
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Subscribed
  3. May 19, 2011 at 2:10 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    if you look at MJP2's truck, he runs inverted LT shackles and his rear squats down when he accelerates. I run flipped Engage shackles on mine and my rear end pics up more than 2 inches when I accelerate
  4. May 19, 2011 at 3:03 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    there is no way u know this. u cant see ur rear end while ur driving. keep ur lies outta here
  5. May 19, 2011 at 3:13 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    its the pucker effect
  6. May 19, 2011 at 8:46 PM
    viperstd
    Maryland
    So MPJ2 is runnign DMZ (styled?) LT shackles inverted (same orientation as stock) and the engage is a traditional shackle orientation right?
    What is the benefit of the inverted setup that drove Toyota to build the trucks the way they are. I assume locating the springs as far outboard as possible to minimize axle leverage on the springs and decrease roll played in the decision. But it seems that the same thing could have been achieved with a traditional setup.
  7. May 19, 2011 at 8:50 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Sub'd.
    Definitely want a shackle flip kit to finish out my rear end.
  8. May 19, 2011 at 8:51 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I have never heard or seen anything about a shackle flipping up and reversing on itself. Usually, the shackle will sit at a 45* angle to the ground. Even when it is fully decompressed it won't make it to 91* because the leaf springs are too long from eye to eye. For the Shackle to flip on itself the axle would have to move itself down AND forward quite a bit. Iirc didn't his flips only give ~0.5" lift? That's not much to be worried about IMO
  9. May 20, 2011 at 5:28 AM
    viperstd
    Maryland
    Shackles getting jammed forward against the frame isn't unheard of. I did a quick google search and found a fair number of people discussing it... however, for every person complaining about it there are probably 500 that don't have issues.
    The 0.5" isn't much at all in itself. however, when the truck is already raked out and has the allpro hitch (which is very high), 0.5" it isn't helping either. I am waiting for my 10" drop draw bar to show up so I can see how terrible the trailer angle is. I may have to accept that I can't pull my motorcycle trailer with the Taco and keep my S10 forever.
  10. Jun 14, 2011 at 6:47 AM
    viperstd
    Maryland
    As an update, I am running the Allpro u-bolt flip kit now. I tig welded the factory bump stops to the top plates until the day that I have hydro-bumps or something trick back there. I know it shouldn't be different and therefore must be psychosomatic, but the truck feels looser in the back now. I snapped a few cell phone pics and will get them up tonight.
    Cheers
  11. Jul 31, 2011 at 6:05 PM
    Oscarbob
    Oscarbob Well-Known Member
    Bob
    Central New York
    '10 DCSB 4X4 OR, Pyrite Mica
    WeatherTec floormats and rainguards, Scanguage, LR UCA, 265/75/16 Duractrac's
    Bump. Anyone else running these? Curious about how they're holding up?
  12. Aug 1, 2011 at 6:55 AM
    malander
    max
    01 limited trd 4x4
    I have the u-bolt flip kit for my first gem sitting in my room. It is beefy, I seriously doubt you're going to have any issues with it. The plate is a 1/2" thick and the bolts are thicker than I expected.
  13. Aug 1, 2011 at 8:48 AM
    viperstd
    Maryland
    I'm still awiting for the new shackle flips to become available.
