Shackle lift suggestions
Discussion in 'Suspension' started by dylandercole, Aug 2, 2009.
  1. Aug 2, 2009 at 5:24 PM
    dylandercole
    dylandercole [OP] Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    Hi i have an 03 4x4 SR5 that i recently put in 3'' spacers in the ront IFS and got AALs for the rear. I noticed the Rear was lower than teh front which is understandable because i still have the stock leaf pack. I wanted to get a 1'' shackle lift for the rear leafs to make up for the sagging and to accomodate the 33s I want to get shortly. If anyone has any suggestions or feedback on what would be a good buy as far as shackles go id really appretiate it. thanks.
  2. Aug 2, 2009 at 7:31 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    with a 3" front, you will want 1.75" in rear to keep the truck even...
    if you already have AAL, you may be at 1.25" to 1.5" so adding a shackle lift would set you up to 2.25" to 2.5"
    your truck would end up sitting like a hot rod...
    how long ago did you put the front lift? what kinda lift was it?
    your front coils may need to re-settle after install...
  3. Aug 2, 2009 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
  4. Aug 2, 2009 at 9:03 PM
    dylandercole
    Dylan
    its a revtek spacer in the frontand i put it in maybe 2 months ago. it was supposed to be a 2.5'' in the back which doesnt seem too far off but you can tell the back is a little lower.
