Shackles??
Discussion in 'Suspension' started by Ktaco, Jul 16, 2009.
  1. Jul 16, 2009 at 1:08 PM
    Ktaco
    Ktaco [OP] Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    I'm going to be fabing up some shackles for my tacoma to give me another inch of lift in the back. Is it true that 2'' longer shackles yeild 1 '' of lift.
    The stock shackle lenght is approx 5 1/4'' so if I make the new ones 7 1/4 inches long that should give me a 1 inch lift increase right.
    I don't wanna make it to high, just enough to make the back level to the front.
    Thanks.
  2. Jul 16, 2009 at 1:27 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Your calculations are correct.
    Careful that you don't go overboard with a shackle lift without extending your bumpstops as well or you run the risk of negative-arching your springs. Just something to consider.
  3. Jul 16, 2009 at 2:04 PM
    Ktaco
    Thanks for the reply. Good advice on the bumpstops. My springs are preety well anyway with 150 000 miles on them. The shackles are just to hold me over until I get some aftermarket spring packs.
  4. Jul 16, 2009 at 2:21 PM
    mjp2
    NJ
    Post before and after shots when you're done. :thumbsup:
