Shady Move from dealership?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by decal211, Nov 13, 2019.
  1. Nov 13, 2019 at 4:16 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Whaaaaaat??:notsure: A competitor’s sales or tech guy told you that one, didn't they? Ive never seen a balance mark on any “real” truck tire.
    auskip07, Boghog1, AthensTac and 2 others like this.
  2. Nov 13, 2019 at 4:17 PM
    AllenOne1
    AllenOne1 Well-Known Member
    Allen
    Nashville, TN
    2013 TRD Sport / 2018 TRD Off Road
    Gen2: Access cab platform, Gen3: MESO Puddle Lights, KTJO Power Folding Mirrors,
    I don't even go back for the free oil changes.
    Winch, 02Duck, mauigrown and 4 others like this.
  3. Nov 13, 2019 at 4:22 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    I installed new wheels and tires 3 months prior so the wheels were never rotated. It was pretty easy to tell as the two front wheels were caked on the inside with brake dust and the rears were clean as a whistle. Showed the service manager and didn’t question it as it was obvious.
  4. Nov 13, 2019 at 4:23 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    That’s actually a real thing. The red and yellow dots on some tires are used to mount tires based on either weight or roundness.
    RobZ9132, rtzx9r, 0xDEADBEEF and 2 others like this.
  5. Nov 13, 2019 at 4:23 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    When I have my Tacoma worked on ( not the Dealer) I'm not in the waiting room but in front of the service bay watching the technician perform the requested work .
    GreyBaldTaco likes this.
  6. Nov 13, 2019 at 4:23 PM
    OnHartung'sRoad
    Ive seen it on performance tires, but not truck tires
    Boghog1 likes this.
  7. Nov 13, 2019 at 4:34 PM
    Trail Limo
    Trail Limo Well-Known Member
    Not true. Those are QA stickers used by the factory. Even if that's what the stickers meant, you can't just align the sticker to the valve stem because that may not be the heaviest/lightest spot on the rim.
    While it is possible to measure the rim and tire weights and match them to get the best possible balance, in practice this only happens on very high end cars, not your normal shop. This is purely due to the time and effort needed to do the work. To match the tire tot the rim, the shop needs to mount the tire multiple times to measure the difference then dismount and re-mount the tire at the measured locations.
    Source. I used to work at a tire shop and was factory trained by the large tire MFG companies.
    Pablo8 and Chew like this.
  8. Nov 13, 2019 at 4:37 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    https://www.topgear.com.ph/features...the-sides-of-new-tires-are-for-a2600-20181008
    https://www.tires-easy.com/blog/what-are-the-red-and-yellow-dots-on-my-tires/
    https://www.yokohamatire.com/tires-101/advanced-information/match-mounting
    whatstcp, CG256 and Stoked like this.
  9. Nov 13, 2019 at 4:41 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    You are incorrect. Whether truck tires use this same method I don’t know for certain, but performance tires and wheels are frequently marked with both the point of least/max weight and least/max radial runout which both affect balance and performance.
  10. Nov 13, 2019 at 4:47 PM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    While calling corporate Toyota is an option, I would start with calling the dealership and speaking to the service manager. Chances are when you call Toyota corporate directly that will be one of the first things they ask you, if you have contacted the dealer to give the dealer an opportunity to address your concerns. If you do not have a positive outcome after contacting the service manager than an escalation to Toyota corporate is in order. But even so, they will put you in touch with the dealer to try to "work out the problem". Regardless, of which path you choose, it appears that the dealership really does not care how good or bad of a job they do. But it is difficult to know if it is a service team member who is cutting corners or if it is a culture that is encouraged by the service manager, owner or entire dealership.
    Evlkarl and Chew like this.
  11. Nov 13, 2019 at 5:00 PM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    Next
    Trail Limo likes this.
  12. Nov 13, 2019 at 5:06 PM
    motogeek
    motogeek Taco Tueday? Tacos Everyday!
    Tacomeat
    America
    Tacoma SR5 TRD 4x4
    2.5 Toytech Inch Lift 285 Cooper SST
    Don't bother with corporate, in a previous thread, someone complained and they said to take it up with your dealership. So they aren't taking any kind of stand for dealers operations. I hope you have another service center you can go to.
  13. Nov 13, 2019 at 5:14 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    They must love it when you show up
    Chew likes this.
  14. Nov 13, 2019 at 5:17 PM
    MikeyD.25
    MikeyD.25 Well-Known Member
    What dealer do you use 'out East' if I may inquire?
  15. Nov 13, 2019 at 5:21 PM
    #35
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I never let a dealers shop work an any vehicle unless the work is under warranty. Don't find another dealer, find an independent shops that you trust. You'll get much better quality work at about 1/2 the cost.
  16. Nov 13, 2019 at 5:25 PM
    #36
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    Yes they do utilize the red and yellow dots for balance
    Taco_Coma and GreyBaldTaco like this.
  17. Nov 13, 2019 at 5:28 PM
    #37
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Are those the -38 Rays?
  18. Nov 13, 2019 at 5:34 PM
    #38
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    Yes sir!
  19. Nov 14, 2019 at 6:03 AM
    #39
    TacORyan4x4
    TacORyan4x4 Well-Known Member
    2018 Cement Tacoma TRD OR
    OP at least if they didn't rotate your tires they can't scratch your wheels. I took mine in last week for 25k service and they rotated the tires, but seemed to do so carelessly and scratched/chipped three of my wheels. I'm still waiting to hear what they will do for me.
  20. Nov 14, 2019 at 6:19 AM
    #40
    Evlkarl
    Evlkarl Well-Known Member
    The Devil,s Bum Phoenix AZ
    2019 black SR5
    nothing big yet Tac Bar K@N Filter Side Steps
    I am pretty happy with my 2 Dealers here in town. Great Service so far. :thumbsup:
