Shake/hop from rear at 42-55 mph (SOLVED)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Coleman42, Aug 26, 2020.
  1. Aug 26, 2020 at 4:36 AM
    Coleman42
    Coleman42 [OP] Well-Known Member
    NH
    14' White TRD Sport DCSB
    5100's @ 1.75, FN F(x) 17x8 0 offset bronze wheels, 265/70/17 Toyo Open Country AT3, Tint, SS3 fog lights, Leer 100XR Topper, Derped Front Emblem, Martin off road foundation rack
    My truck is a 14 DCSB 5100s @ 1.75” and 1.5” toytec aal. Currently at 97k miles and I’ve been chasing this for a while now. It started when I got new tires The tires are for sure balanced (had the shop check it twice) I have check the center carrier bushing and done the drop kit, it seemed to do nothing.
    here’s the screwy part.
    It’s at precisely 42mph
    It seems to be worse with my hitch rack and mountain bike on the back, BUTTTTT with my hitch rack and yz250 dirtbike it all but goes away!
    It’s not dependent on what gear I drive in, 4 or D
    And it’s not dependent on the load on the powertrain (not worse going up, down, or flat
    I’m lost.
    EDIT (10/11/20) swapped the wheels and tires between my wife’s 2020 4 runner and it is the issue. So I will try a different set of tires.
    EDIT (11/28/20) ordered plastic hub centric rings 108-106mm and it somewhat solved the problem. The only thing I can think of is that I removed the center caps of the wheels and that small difference was enough to make the difference and the rings made that back up.
    EDIT (8/5/21) still having the issue. Been running the trd trail wheels off my wife’s 4 runner for a few days and I decided to dump my pro comp 7005 wheels and BFG KO2 tires and Ordered some FN FX pro wheels and toyo open country at3 tires with new TPMS. I’m convinced the pro comp wheels are hot garbage and have been the problem the whole time and the only constant through the entire issues life. Will post final finding when new tire/wheel set up arrives
    EDIT (8/14/21) FINALLY SOLVED 100% it was the wheels they were pro comp 7005 they were the only constant thing with the vibe. So changing all those parts was useless but I guess you win some and you lose some.
    cytocycle and Torspd like this.
  2. Aug 26, 2020 at 5:06 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    You say it started when you got new tires. There is the biggest clue. If it didn’t exist prior to the tires seems like that’s where you need to start.
  3. Aug 26, 2020 at 5:11 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    AALs l I've heard can sometimes change the driveshaft angle, it should be easy to measure. It is possible you could be getting some axle wrap. Check YouTube how to properly measure that.
  4. Aug 26, 2020 at 5:14 AM
    Clearwater Bill
    Billy
    Largo Florida
    Rotate tires front to rear and see if there is a change.
  5. Aug 26, 2020 at 5:14 AM
    LoveableWerewolf
    Nashville
    That's easier, do that first.
    Alexely999 likes this.
  6. Aug 26, 2020 at 5:18 AM
    Coleman42
    NH
    The other thing is it always stays as a vibe of sorts in the back even after I rotate as well
  7. Aug 26, 2020 at 5:22 AM
    LoveableWerewolf
    Nashville
    Can you stick those tires on another car? I'm just spitting ideas about tires. Could be bad batch, my dad had something like that before, except it was 57mph.
  8. Aug 26, 2020 at 5:31 AM
    gotoman1969
    Where the tires road force balanced?
    Kolter45 and gearcruncher like this.
  9. Aug 26, 2020 at 5:48 AM
    Coleman42
    NH
    Yes I could try them on my wife’s 4 runner
  10. Aug 26, 2020 at 5:48 AM
    Coleman42
    NH
    I’m not 100% sure about that.
  11. Aug 26, 2020 at 6:00 AM
    Pyts
    Pyts Well-Known Member
    09 2.7 RWD
    Stock
    Having myself spent a few years working for a large chain tire shop I feel confident saying that if your tire/wheel assembly is on the large side, if the face of the wheel is recessed significantly (preventing tape weights from being applied in a dynamic way), if the shop is busy, yeah, you may still have completely imbalanced wheels.
    Could yuh take a picture showing the weights on the wheels? I'd like to see how much weight they loaded on and if it's on both the inboard and outboard side.. If you're within 30 days of purchase you may be able to return them claiming a complaint of ride quality.
    wilcam47, Kolter45 and Biscuits like this.
  12. Aug 26, 2020 at 6:13 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I would buy a cheap set of stock take offs, and put them on your truck and go for a drive. If you don’t have the vibes, you’ve found your problem.
  13. Aug 26, 2020 at 6:16 AM
    gotoman1969
    Completely different rear suspension. Different weight etc. No need to do this.
  14. Aug 26, 2020 at 6:18 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    He could take the wheels from the 4runner and try them on his Tacoma though.
    Kolter45 likes this.
  15. Aug 26, 2020 at 6:22 AM
    gotoman1969
    Yes. That he could do.
    Pyts and Alexely999[QUOTED] like this.
  16. Aug 26, 2020 at 6:49 AM
    Pyts
    09 2.7 RWD
    Stock
    To clarify on the request for a pic, I sure as heck can't tell if they're balanced by looking at the weights, but if there's a bunch of them, if they're all in one place or stacked on top of each other/just on one side.
  17. Aug 26, 2020 at 7:02 AM
    Coleman42
    NH
    I will check out the weights when I get a chance. But I know the weights were put in 2 different spots. Like toward the inside and also towards the wheel face. My uncle works at a Toyota dealership and he is the one that mounted and balanced initially and then checked a second time and said they were perfect. I just don’t get how even after rotation the symptoms stay the same.
    could a u joint cause this to happen ?
  18. Aug 26, 2020 at 7:03 AM
    Coleman42
    NH
    I could try. Not sure how stoked she’s going to be about me stealing the wheels off it with only 300 miles on it though :boink:
  19. Aug 26, 2020 at 7:11 AM
    gearcruncher
    Canadain bumper technician
    lynyrd3, Biscuits and ardrummer292 like this.
  20. Aug 26, 2020 at 7:13 AM
    Coleman42
    NH
    lynyrd3 and Alexely999 like this.
