Shake in front end after installing 3 inch lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacomagirl2, Aug 3, 2017.
  1. Aug 10, 2017 at 5:33 PM
    #61
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    You cant return them? You should be able to. You may be able to go direct to General as well. They are factory defects.
  2. Aug 10, 2017 at 5:35 PM
    #62
    harrycary
    harrycary Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    Make a big fuss. If the tires suck, prove it, and get your money back. Do take their sh!t.
  3. Aug 10, 2017 at 5:42 PM
    #63
    Tacomagirl2
    Tacomagirl2 [OP] Active Member
    Virginia
    2017 Tacoma TRD Sport 4x4
    3 in lift, Mikey Thompson Wheels, and General Grabber AT2 tires
    I plan on calling the general manager of the tire center at Walmart tomorrow.
    If I don't get anywhere with him I will try and call General tires directly.
  4. Aug 10, 2017 at 5:55 PM
    #64
    -JDC-
    -JDC- Well-Known Member
    2017 TRD Off Road
    That sucks. I had this happen with a BFGoodrich tire that couldn't keep balance. The balance would work for a while then go back to crap. Spent way too much on repeated balancing before I realized it was impossible (thanks to a Les Schwab guy for finally pointing out this tire was junk). I tried for a while to get some kind of recourse, but ultimately I ended up buying a complete set of new tires because I was going on a road trip and the shaking would have driven me insane. I don't know if these kind of things are a fluke or not, but I will never buy BFGs again.
  5. Aug 10, 2017 at 6:01 PM
    #65
    Tacomagirl2
    Virginia
    This is our 4 th set of General Grabbers AT2 ( had on other vehicles in the past) and never had problems with them. This is why we decided to go with them again.
  6. Aug 10, 2017 at 6:11 PM
    #66
    Thesandaddict
    Thesandaddict The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
    I would not go to walmart for anything auto related. I have the grabber at/2 as well. They were fine for almost a year. Started to notice a shimmy north of 50mph. Finally took the truck to a reputable tire shop (not like a big o or just tires, find an old school place with old guys that know what theyre doing). My best tire was 3 ounces out of balance, the worst was 7 ounces. Thats....a lot. Big o tires coule never get the truck perfect, just close. Now its spot on.
  7. Aug 11, 2017 at 1:38 AM
    #67
    Tacomagirl2
    Virginia
    According to the guy doing the road force testing, the back tires were 4 lbs out of balance. This is why he said they were bad tires and needed to be replaced or he suggested beading (?).
    Kolunatic likes this.
  8. Aug 11, 2017 at 1:51 AM
    #68
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I've seen where the tire is repositioned on the rim and rebalanced
    303tacoma likes this.
  9. Aug 11, 2017 at 4:58 AM
    #69
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Kolunatic[QUOTED] likes this.
  10. Aug 11, 2017 at 5:05 AM
    #70
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    303tacoma[QUOTED] likes this.
  11. Aug 11, 2017 at 5:07 AM
    #71
    Tacomagirl2
    Virginia
    303tacoma, thanks for the link. Very interested read and I quoted the lbs wrong. He said Walmart had put 4 lbs of weight on the tires and the Dealership that did the testing said that was excessive. Dealership stated the tires were 42 lbs out and he considered them to be bad tires needing replacement.
    Kolunatic and 303tacoma like this.
  12. Aug 11, 2017 at 5:10 AM
    #72
    303tacoma
    Rebecca
    Yes my caster is set at 3.1
    I had my coopers road forced right from the beginning knowing they were a heavy tire,also I've been told a dynamic balance is better than static.
  13. Aug 11, 2017 at 5:13 AM
    #73
    303tacoma
    Rebecca
    Static being up and down
    Dynamic being side to side
  14. Aug 11, 2017 at 5:22 AM
    #74
    harrycary
    Harry
    Does anyone know the stock caster and toe settings for the TRDs. It would be interesting to compare the Sport and the Off Road.
  15. Aug 11, 2017 at 6:23 AM
    #75
    303tacoma
    Rebecca
    I'm pretty sure the factory specs are the same for both off road and sport
    With a lift and aftermarket UCAs caster is set higher than factory specs (to deal with the wandering when driving)
    harrycary[QUOTED] likes this.
