Shakes to much!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Joelito2983, Nov 28, 2009.
  1. Nov 28, 2009 at 5:11 AM
    Joelito2983
    Joelito2983 [OP] Well-Known Member
    Ok, so i installed my light behind the grill and use the two holes on the radiator suport to put the fog lights.... i use scooter clutch weights to bring the lights alittle bit down and tighten the screw...i noticed that radiator suport is real thin and basiclly you can bend it so easily.
    When i when to go and try the lights out on the highway the lights just start shaking as i drive and im pretty sure i tighten them so much i didnt want to brake the bolt...any advice would be really apreciated
  2. Nov 28, 2009 at 5:32 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    :worthless:scooter clutch weights???sounds like u need more support.
  3. Nov 28, 2009 at 6:04 AM
    Joelito2983
    I have a motorcycle shop so i had to improvise with what i got!!! Im at work so i dont have pics of the install or the fog lights.
    Here are pics of what i used bit in a bigger size!! I used three on each light so i can drop it from the suport about 1 1/2 inches
  4. Nov 28, 2009 at 7:19 AM
    pataco
    Down by the lake
    05 4x4 trd dc white
    O,there shims.gottcha.thats probally why they r shaking.to much hanging down/up.
  5. Nov 28, 2009 at 7:49 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    13 Taco Double Cab TRD
    Bilstein 5100's all around, front set at 2.5", Toytec AAL, 265/75/16 Duratracs, Pro Comp 5001, Weathertech's, AVS In Channel Visors, Nokya Hyper Yellow fogs, CB Set up, Color matched grill surround, ATC Camper Shell with Yakima Racks, SOS Concepts Regular Rear Bumper.
    Im not sure exactly which holes you are talking about, but what I did with mine, was I went to Lowes and got an aluminum bar and mounted above and below my bolts to strengthen the area. Its not attached between the lights on the top, just on the bottom. On the top I cut them in about 5" lengths. Let me know if you want more detail, but this worked for me. No shaking.
  6. Nov 28, 2009 at 8:13 AM
    Joelito2983
    if you have any pics i would really apreciate it!!!
  7. Nov 28, 2009 at 8:24 AM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    Mine do the same damn thing. So annoying. Its only bad on the highway/ freeways
  8. Nov 28, 2009 at 8:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You will have to fab up a more solid mounting point to eliminate the shaking. 1 way, is to make a mount on the upper support (the one in which the horns mount), and attach the lights to that one also. That way, there are 2 points in which to hold the lights steady.
  9. Nov 28, 2009 at 8:36 AM
    AriZonaD54
    Andrew
    Valley of the Sun
    I dont have a photo at the moment.. but I figured they would wobble, so I fabricated two L brackets for extra strength. The lights aren't going anywhere and the mount is incredibly strong, but on the highway I still get a little moment that is exacerbated by inconsistencies in the road. Dah well.
  10. Nov 28, 2009 at 10:45 AM
    Joelito2983
    Thats where i have my lights set up on the two holes on the radiator suport
  11. Nov 28, 2009 at 10:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can either reinforce the support, or make a connection to the lower support as well. That should stop the vibes.
