shakey idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Feb 4, 2011.
  1. Feb 4, 2011 at 2:46 PM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    When my truck is idling, the motor is a little shakey and very annoying. The RPMs drop, the truck rattles real quick, then the RPMs go up a little (this process happens over and over). What's going on here? Can I increase the RPMs that my truck idles at?
  2. Feb 4, 2011 at 4:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Chekc the vacuum lines
  3. Feb 4, 2011 at 5:00 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    I don't think you can change the idle. This process has happened to my truck for several years. Does it happen when the truck is in drive and the brake is held?
  4. Feb 4, 2011 at 8:27 PM
    DaytonLax14
    Corey
    Ohio
    What exactly am i looking for when I check them? Just making sure they aren't loose and nothing blocking them?
    yes. happens in nuetral, drive, and park
  5. Feb 5, 2011 at 12:01 PM
    DaytonLax14
    Corey
    Ohio
  6. Feb 5, 2011 at 2:00 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    the shaking is all that power under the hood!!:thumbsup:
  7. Feb 5, 2011 at 6:14 PM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    My truck shakes... alot, get use to it.
    Check your motor mounts maybe?...
  8. Feb 5, 2011 at 6:23 PM
    kingbrian
    kingbrian Resident Big mouthed Fat ass.
    brian
    I.E. CA.
    98 2.4 5 speed xtracab
    Fagtech spindles, Doug Thorley header, Spintech muffler, JVC headunit.
    mine does it also, idles around 600 regularly. sometimes drops to 400-500ish then back up. i wish i could turn it up to around 800-850. ill try some maintanence and FI cleaner and see if it helps.
  9. Feb 6, 2011 at 8:03 AM
    DaytonLax14
    Corey
    Ohio
    that sounds exactly like mine. When I'm at a stop light I'm afraid the engine is going to stall. Let me know if FI cleaner helps
  10. Feb 6, 2011 at 8:31 AM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    Go buy some FI cleaner, costs $3.99 and try for yourself
