Shaking at 55mph after replacing wheels and tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 315TACO, Dec 4, 2021.
  1. Dec 4, 2021 at 11:27 AM
    315TACO
    315TACO [OP] New Member
    14 Tacoma 4WD
    I bought a set of wheels and tires off marketplace from a 3rd gen tacoma. The tires looked brand new and it was a great deal. Mounted them on my 14 tacoma and they shake starting around 55. Had them balanced and the issue persists. Took them to another shop and they were rebalanced and they replaced all of the lug nuts. Still didn’t fix the issue. If I put my stock wheels and tires on the truck it rides perfect. Do these wheels just not fit on the 2nd gens?
    Also, the shake isn’t consistent. Sometimes it’s smooth at high speeds, other times it shakes like hell.
  2. Dec 4, 2021 at 11:56 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Did you get a static balance or roadforce balance?
  3. Dec 4, 2021 at 12:51 PM
    10YSON
    10YSON Well-Known Member
    GREG
    TACOMA & 4RUNNER
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
    If the tire sizes are the same, you could put all 4 stock wheels on and then add the new wheels one at a time to isolate the wheel with the issue.
    winkel and steelcity2 like this.
  4. Dec 4, 2021 at 12:52 PM
    315TACO
    14 Tacoma 4WD
    Static balance.
  5. Dec 4, 2021 at 2:07 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Are all the rims true?
  6. Dec 4, 2021 at 2:15 PM
    315TACO
    14 Tacoma 4WD
    I haven’t put the tires on the original rims yet. My suspicion is one of the rims are messed up.
  7. Dec 4, 2021 at 2:40 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    What kind of tires are on the 3rd Gen rims? Are they OEM or replacements? I know sometimes folks have balance issues when they upgrade to certain brands of all/mud terrain tires. A road force balance can help detect if you have a problem tire(s) on hand.
    Like @10YSON mentioned I'd also be trying to isolate the problem wheel/tire one at a time.
  8. Dec 4, 2021 at 2:44 PM
    315TACO
    14 Tacoma 4WD
    The tires are Cooper A/Ts
  9. Dec 4, 2021 at 2:52 PM
    Clearwater Bill
    Billy
    Largo Florida
    Road force balance with a tech that actually is trained on the machine and will do the extra work that it sometimes takes.
    It will detect a bent wheel or bad tire.
    3rd gen wheels fit fine. And unless your 2nd gen lugs had the wrong seat face you didnt need new ones
  10. Dec 4, 2021 at 3:01 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Static balance is the quick and easy way with weight on one side only, it's rarely sufficient for bigger truck tires
    It's needs a dynamic balance (inner/outer weights) at the very least
    I don't have any experience with road force balancing but I've heard good things about it
  11. Dec 4, 2021 at 3:03 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Take a look at the amount of weight on each wheel. If one has a lot more then the others or is counter balanced that’s probably the problem wheel.
  12. Dec 4, 2021 at 3:10 PM
    2015WhiteOR
    Gainesville TX
    Is it possible the wrong lugnuts are being used? Cone vs flat?
  13. Dec 4, 2021 at 3:52 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Im going out on a limb and state that it's likely reason the seller sold them for cheap, especially if the tires look new. Another recommendation for road force balancing.
  14. Dec 4, 2021 at 3:53 PM
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    Road force balance, for sure.
