Shaking at startup and delay!
Discussion in '1st Gen. Tacomas (1995-2004)' started by akrinar, Dec 1, 2019.
  1. Dec 1, 2019 at 2:04 PM
    akrinar
    akrinar [OP] Well-Known Member
    2002 Tacoma 2.7 - 4 cylinder - PreRunner
    I have Tacoma 2002, Engine: 2.7 4 Cyl!
    I did not have any problem until today! My truck start with delay and it shake/vibrate [during startup] once I'm turning car ON!
    Temp of area is 40 F.
    I'm not sure if it's from Misfire or fuel pump!
    Note: There is no message on OBD too!
    Any idea or previous experience?
  2. Dec 1, 2019 at 2:19 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    We need some info, general location, miles on vehicle, auto or manual transmission, maintenance and repairs that have been completed, etc.
  3. Dec 1, 2019 at 2:26 PM
    akrinar
    It's 100,000 miles!
    Change spark plug at 70,000 miles!
    Auto-Transmission
    Regular maintaining!
    The major part never changed!
  4. Dec 1, 2019 at 2:45 PM
    IFGD
    IFGD Well-Known Member
    Ian
    Raleigh, NC
    2001 Regular Cab 2.7L
    Why are you so excited!!?
    Lawfarin likes this.
  5. Dec 1, 2019 at 2:49 PM
    akrinar
    Why should I be sad? :) Are u able to give advise?
    Tnx
  6. Dec 1, 2019 at 3:37 PM
    cruiserguy
    Elijah
    SEKS
    Is the MIL illuminated? Even if it's not on currently yet it may have a DTC pending.
    What else happened? Describe step by step the starting and driving process and then what is different. Is the idle rpm low?
    Have you already searched through the tons of threads here to see if something matches your symptoms and conditions?
    So you have a rough idle or a misfire?
  7. Dec 2, 2019 at 2:27 PM
    akrinar
    Here the sound and the way car start!Listen to the sound at end too!
  8. Dec 2, 2019 at 2:29 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Sounds flooded. Was the key left on whyle the engine not running?
  9. Dec 2, 2019 at 2:33 PM
    akrinar
    No, It's just acting recently without any reason! it happen when weather cold, usually less than 45 F.
  10. Dec 2, 2019 at 2:34 PM
    cruiserguy
    Elijah
    SEKS
    Does it start like this after its been running and turned off and then restarted? Or is it only on cold start ups?
    You smell raw gas outside of the truck after this happens?
  11. Dec 2, 2019 at 2:35 PM
    akrinar
    After a while the car get better! Mostly take time to turn ON! And yes, I can smell the GAS too!
  12. Dec 2, 2019 at 2:37 PM
    stiover
    stiover Well-Known Member
    Corey
    2004 DCSB
    Bilsteins Toyotec Springs OME Dakar leafs TE37X w/ 33s
    Stuck injector?
  13. Dec 2, 2019 at 2:38 PM
    akrinar
    I do not know! I did not check that!
  14. Dec 2, 2019 at 2:41 PM
    cruiserguy
    Elijah
    SEKS
    I need a yes or a no answer on this one, after the Tacoma has been stopped, if you try to start it back up does it do this same problem?
  15. Dec 2, 2019 at 2:42 PM
    akrinar
  16. Dec 2, 2019 at 2:43 PM
    akrinar
    Sometimes Yes! If i do immediately after what happened!
  17. Dec 2, 2019 at 2:46 PM
    akrinar
    But, After 5 min driving it's not going to happen at All! Until the car stay for a long hours OFF again! Then it acting Most of time! NOT ALWAYS!
    cruiserguy likes this.
  18. Dec 2, 2019 at 2:48 PM
    akrinar
    I attached my OBD screen too! Maybe it help to find out anything out of Data!
  19. Dec 2, 2019 at 2:53 PM
    cruiserguy
    Elijah
    SEKS
    After the truck is driven somewhere and then turned off, does it restart normal and without issue?
    Need more details on your symptoms to help. We're trying to determine between injector stuck open and dripping gas into cylinder while engine is off, or if there are ignition problems and not combusting the air fuel mix as it should.
    Do you do your own work? Or do you take it in for service? If you don't do your own work I don't want to type up a bunch of stuff that won't matter because you're taking it in anyways. Know what I mean? Lots of info to search through here too. Lots. And your issue and symptom isn't rare. Lots of info you can read through here
  20. Dec 2, 2019 at 2:55 PM
    cruiserguy
    Elijah
    SEKS
    Okay this is what I was trying to get from you! Perfect! I think you have an injector stuck open when engine is turned off and it drips fuel into the cylinder and causes a hard start condition. The longer the engine sits, the more fuel that can leak in and cause this condition. And this is why starts fine after running for few minutes and then turning it off and restarting
    You can try cleaning the injectors or you may just have to replace the one that is acting up.
