Shaking During Acceleration - Rear Leaf Springs and Shocks?
Discussion in 'Suspension' started by everetse, Dec 12, 2011.
  1. Dec 12, 2011 at 6:44 AM
    everetse
    everetse [OP] Member
    Hi All,
    2006 Tacoma, V6, rear wheel drive.
    Within last week, a hard shake during acceleration developed. Wasn't towing or carrying a heavy load. Dealership says we need new rear leaf springs and rear shocks. Total = $2000 ($1600 parts, $400 labor).
    I've seen a lot of threads regarding the rear leaf springs / rear shocks causing a rough ride and the TSB - but doesn't sound like it causes a violent shaking during acceleration.
    Something to keep in mind - dealer first thought it was a bad engine mount. After replacement, turned out not to be the issue. The rear springs/shocks is also a 'guess' to what the problem is.
    Any thoughts? I'm pretty clueless when it comes to suspension - so any advice is appreciated. Wanted to get some expert opinion before dropping that kind of money into the truck.....
    Thanks!
  2. Dec 16, 2011 at 12:57 AM
    rdm197aps
    rdm197aps Well-Known Member
    Rick
    DFW
    10 TRD Sport 4x4
    ARB bulbar WARN M8000, OME/Dakar, enough recovery gear to yank a GEO Tracker outta ditch!
    try the u joints on the drive shaft. had an s10 about 15 years ago that had that problem. new MOOG u joints and the problem was gone.
  3. Dec 16, 2011 at 10:00 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    x2, and you said hard shake,then violent.........worn rear leafs shouldnt make violent shakes.mine are worn bad and i just get vibes(and bad squat)when i hammer on it from a dead stop.
