Shaking steering wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yoda9, Sep 1, 2016.
  1. Sep 1, 2016 at 5:30 PM
    Yoda9
    Yoda9 [OP] Member
    Hey guys I recently did a few mods to my 2011 access cab 4 cyl. I put billsteins all around and set the front to 1.75, wheelers 3 leaf progressive in the rear, and I put on some 265/70r17 duratracs with black rhino wheels. I had the tires mounted and rotated and I had the alignment done today and the steering wheel is shaking when I'm at speeds around 45 or higher. Can anyone tell me what the problem might be?The guy at meineke who did the alignment said I should get a new steering stabilizer but I have read around and people are saying that shouldn't be the problem. If anyone has an answer or input I would really appreciate because it's bothering the hell out of me. I'm also getting some squeaking whenever I hit any little bumps and it sounds like it's coming from the uca's but I really don't have a clue. Any input would be great people. Thanks!
  2. Sep 1, 2016 at 5:52 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Boy you changed a lot at once. Makes it harder to isolate the issue. That said, I would say balance is most likely the main culprit. Get the wheels balanced with a Road Force balancer. Here is a shop locator:
    http://www.hunter.com/gsp9700
    Call the closest shop, and ask if they have Haweka adapters. These are adapters that mount the wheel to the balancer through the lug holes on the wheel. Especially helpful when balancing lug centric wheels which I'm guessing yours are. Also make sure if the bore diameter of the wheels is bigger than 106.1 mm that you have hub centric rings for them.
    DrFunker, Jimmyh and Yoda9[OP] like this.
  3. Sep 1, 2016 at 5:53 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I think that adapter only applies to OEM wheels and OP has aftermarket.
  4. Sep 1, 2016 at 5:54 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Duratracs are notorious for not balancing correctly and causing vibrations. I use to have them and could never get them to balance at any shop.
    t(u)rdtaconator likes this.
  5. Sep 1, 2016 at 5:57 PM
    Yoda9
    Yoda9 [OP] Member
    Yea I was driving with the billies for about a month before I got the tires and everything seemed fine. As soon as I got the tires it started. So can I rule out that it doesn't need a steering stabilizer?
  6. Sep 1, 2016 at 5:57 PM
    Fitz235
    Rob
    New Hampshire
    The Haweka adapters can be used on either factory (hub centric), or aftermarket lug centric wheels, but are a key component when trying to balance lug centric wheels.
    T4RFTMFW[QUOTED] likes this.
  7. Sep 1, 2016 at 6:13 PM
    Yoda9
    Yoda9 [OP] Member
    The guys who put them on put black rings on my hubs before putting the tires on. Are these what your talking about?
  8. Sep 1, 2016 at 6:15 PM
    moondeath
    Pa, Gardners
    Those are hub centering rings to center the wheel on the hub.
    Yoda9[OP] likes this.
  9. Sep 1, 2016 at 6:22 PM
    Yoda9
    Yoda9 [OP] Member
    Okay should I still try and find the haweka adaptors and try the balance with them or.. I'm just really lost with what I should do, I'm definitly going to try a Balance again. Does anyone have any info with the squeaking noise I get when i hit every little bump
  10. Sep 1, 2016 at 6:25 PM
    mhorton1911
    mhorton1911 Fightin' Texas Aggie Class of '19
    Mark
    Fort Worth
    2000 2.7 4x4 manual
    Trail Gear front and rear bumper, 5100's all 4 corners, Eibachs, toytec AAL 1980 Ford pickup horn, and lots of battlescars :)
    I had a similar problem, more than likely your tires arent balanced
  11. Sep 1, 2016 at 6:28 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    All depends where the squeaking is coming from. With your truck parked (obviously) grab the bed rails and shake it, or jump up and down on your rear bumper. That'll tell you if its your leafs or not.
  12. Sep 1, 2016 at 6:36 PM
    Dynosports
    Dynosports Throw more parts on it and it will go fast.
    Taylor
    Menifee
    2015 DCLB 4x4
    The black rings should make the wheels hub centric. That is good as long as they are the correct size.
    You could put a wrench on your suspension parts to make sure nothing was left loose but I would take it back to have the wheels/tires balanced.
    Then I would test drive to make sure it is fixed.
  13. Sep 1, 2016 at 6:46 PM
    BadAndy10
    BadAndy10 Well-Known Member
    the 541
    '10 DC TRD OR
    Fox 2.5" extended travel coilovers, SPC UCA's, Wheeler's AAL & 5100's, Relentless front plate bumper, SCS F5's w/285's, Superbumps
    Your tires aren't balanced correctly, take it back to the tire shop and ask them to have their best guy do a roadforce balance. I've had similar issues w/my duratracs, it's not unheard of.
  14. Sep 1, 2016 at 6:51 PM
    Yoda9
    Yoda9 [OP] Member
    Okay
    Squeaking is coming from the passenger side front. It happens with every small bump. I usually just turn the tunes up but I still know it's there and it bugs me haha. I'm bringing it to the shop tomorrow maybe they can figure it out
  15. Sep 1, 2016 at 6:52 PM
    Yoda9
    Yoda9 [OP] Member
    And thanks everybody for the info I'm bringing it back to the shop tomorrow
  16. Sep 1, 2016 at 7:01 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Huh, that's really odd. Curious to see what the shop says. Could be the bushings in the control arms or something.
  17. Sep 1, 2016 at 7:18 PM
    soupisg00df00d
    soupisg00df00d Well-Known Member
    Mark
    Eastern North Carolina
    2012 White Tacoma V6 4x4 6 speed manual
    Bilstein 5100s 884s Toytec prog. AAL SPC UCAs ProComp 5001s 16x8 Copper discoverer RTX 265/75r16 Black rear bumper Color matched grill surround
    NTB will do a road force balance with the Haweka adapters. I think all of their sister companies do it to.
  18. Sep 1, 2016 at 11:50 PM
    David_A
    David_A Well-Known Member
    san diego ca
    procomp leveling kit,77series k&n cause it looks cool i guess
    Yeah rebalance them i had the same issue i got them rebalanced and problems where gone
  19. Sep 2, 2016 at 12:29 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Getting balance with roadforce is key
  20. Sep 2, 2016 at 5:47 PM
    jnmargarit
    jnmargarit Well-Known Member
    Vancouver, B.C.
    '14 TRD Sport
    Just went through the same shaking in the steering wheel. Rotate your tires and see if the problem is still there.
    That's when my shaking started and had them balanced and they're good now.
