Shaking steering wheel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GreytDirt, Jan 23, 2019.
  1. Jan 23, 2019 at 12:52 PM
    GreytDirt
    GreytDirt [OP] New Member
    Dimitri
    2017 Tacoma SR5
    So I put some new Scs ray 10s and a set of falken wildpeak at3w. Love the set up. Today was the 3rd time balancing and rotating the tires at Toyota. The first 2 times was at a local discount tire store. My steering wheel is still vibrating after 50 mph. Anybody else with same set up has similar issues or knows what might be wrong cause I’ve been hating to drive my truck lately because of this.
  2. Jan 23, 2019 at 1:15 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Have them watch the tires as they are being balanced. You may have a bent rim or a out of round tire.
  3. Jan 23, 2019 at 1:16 PM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    alot of problems with these tires,, wildpeak at3w,, should have paid up and got something good.. m2c
    na8rboy likes this.
  4. Jan 23, 2019 at 1:25 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Nothing wrong with the Falkens...willing to bet one of the front brake rotors is warped from putting the wheels on with an impact wrench...check the run out on the rotors and you’ll see...
    shakerhood likes this.
  5. Jan 23, 2019 at 1:49 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have those tires too, zero vibration.
  6. Jan 23, 2019 at 2:08 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Did you buy them the end of last year?
    I think they had a bad run...
    It took one member 9 tires to get 4 round ones.
  7. Jan 23, 2019 at 3:36 PM
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    I just put some duratracs on my 18 and at certain speeds I’ll get a minor vibration in the wheel as well. Oem off-road wheels.
  8. Jan 23, 2019 at 3:46 PM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    Here's something that I noticed when I installed BFG A/T KO2's on my aftermarket wheels. Discount Tire initially balanced them a certain way and the steering wheel shook badly, just like you're indicating. I took it back and the manager of the store came over to me (I got there before they opened the next morning) and he said, what's up cause he knew I was there the day before? I said, the steering wheel is shaking like crazy and he just took my keys. 20 minutes later he handed them back to me and said "it should be good to go". He balanced them using a different method (not road force) and he was right, it was perfect. The rear wheels/tires are balanced the old way and don't vibrate, but he said when I rotate, they would need to rebalance the rears to match the balancing method in the front. You can always take it to a place with Road Force, which can help. The other thing that could help is hub-centric rings, if the bores don't match up with the hub diameter. I ordered custom aluminum rings for my 15 Tacoma to match my wheels, so I knew that wasn't the issue.
    I think it comes down to who's doing the balancing. That guy has always done me right.
  9. Jan 23, 2019 at 3:55 PM
    MrGooch
    MrGooch Well-Known Member
    2021 Black TRD Pro
    That's all bullshit, although some may have defects they all have standards. Had same issue with a new set on my srt Cherokee when I had it. Took it back to Jeep, they did a pro grade alignment and tire balance and the are was fine. Dont let a shitty tire place do it.
