Shaking Under Truck
Discussion in 'Technical Chat' started by Dixiepek, Nov 17, 2010.
  1. Nov 17, 2010 at 3:12 PM
    Dixiepek
    Dixiepek [OP] Member
    Columbia, SC
    3" Toytec Spacers and AAL's
    My truck recently started shaking when i get to around 40mph, like it can't switch gears. When i let off the gas it goes away and then when i hit it again it starts shaking. It doesn't happen all the time but it's to the point where it's going to the shop. Anyone have a similar problem or experience? It's a 2003. Hope i'm in the right thread.
  2. Nov 17, 2010 at 3:14 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    does it shake from that speed and up? or just around the 40mph mark?
  3. Nov 17, 2010 at 3:26 PM
    Dixiepek
    Columbia, SC
    doesn't seem to. 40-50mph seems to be when it happens. just on acceleration. tires were just balanced and everything. just had an oil change. it kinda feels like when your ABS brakes hit. that jolting feeling. i'm saying transmission
  4. Nov 17, 2010 at 6:17 PM
    grandpa
    grandpa New Member
    Dennis
    virginia beach,va
    2011 tacoma,4 auto 2wd access
    A bad ujoint in driveshaft will cause those symptons.Does it also have a squeek when backing up slowy? hope this helps
  5. Nov 18, 2010 at 12:55 PM
    Dixiepek
    Columbia, SC
    no squeak when backing up that i heard. not to say that it wasn't though. it's in the shop right now. how costly is it to get this fixed if it was a bad u-joint and would a lift cause this problem?
  6. Nov 18, 2010 at 7:54 PM
    TacoBow
    TacoBow Intentionally cosmetically incorrect.
    PA
    2012 Tacoma SR5 4x4 Access Cab
    U-joints aren't expensive for the most part... likely charge you more in labor than for the U-joint itself. Fairly simple install.
    As far a lifts, sure, the angle added to the driveline can and often does result in premature wear.
