Shaking violently when taking off
Discussion in '1st Gen. Tacomas (1995-2004)' started by benjammin5150, Oct 16, 2013.
  1. Oct 16, 2013 at 9:34 AM
    benjammin5150
    benjammin5150 [OP] Active Member
    vancouver wa.
    99 2.7L SR5 4X4
    Ive searched the forums but couldnt come up with an answer to my problem.
    99 2.7L 4x4 5speed 115000
    When Im taking off in first my truck shakes and kinda sputters like its having a hard time. Also the idle is very rough now. It just started having this problem this morning. I was driving down the road and everything was fine, then I down shifted to second and as I was letting out the clutch it started shaking and didnt want to go. I came to a complete stop and noticed the idle was rough, but consistent at 750RPM. I went to take of and the shaking started.
    I know I have bad U-joints, but this couldnt cause the idle problem. I changed the spark plugs 3000 miles ago, but didnt do the wires. No CE light.
  2. Oct 16, 2013 at 10:35 AM
    gearcruncher
    Canadain bumper technician
    Change the universal joints and do a good engine tune up . Those are the basics .
    Plugs, wires , air filter , fuel filter . Did you use Denso plugs ? Clean the throttle body ?
    Once this is done , at least you have a base line .
  3. Oct 16, 2013 at 2:16 PM
    benjammin5150
    vancouver wa.
    99 2.7L SR5 4X4
    pulled codes...Said P0303 short or open circuit, #3 misfire. P1300 igniter circuit malfunction, P1310 igniter circuit malfunction #3. changed coil pack didnt solve the problem. Now Im getting back fires and CE light is blinking. Now looking at crankshaft position sensor. Is it hard to replace? It starts fine and runs fine for a few minutes, but starts misfiring shortly afterward. Do these sound like symptoms of a bad crank sensor?
  4. Oct 16, 2013 at 3:07 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    Could be a bad injector. Do a resistance test.
  5. Oct 18, 2013 at 9:07 AM
    benjammin5150
    vancouver wa.
    99 2.7L SR5 4X4
    Found the problem...Pulled the #3 plug to look for signs of running lean due to bad injector...found water in the spark plug well. Im assuming it was from the car wash I took it through the other day. Changed the wires to get a better seal. Im glad it was a simple fix.
  6. Oct 19, 2013 at 12:02 PM
    tan4x4
    Rick
    Folsom, CA
    Thanx for letting us know what the solution was. Glad it was simple and cheap.
  7. Oct 19, 2013 at 8:17 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    +1
    I always appreciate it when the OP comes back to the thread and gives is resolution/closure.
    Helps in the future when searching for symptoms, etc.
  8. Oct 20, 2013 at 10:37 AM
    benjammin5150
    vancouver wa.
    99 2.7L SR5 4X4
    I made the mistake of buying duralast wires because of the lifetime warranty. They dont seal well at all. Have NGK on the way.
