Shaking while breaking :/
Discussion in 'General Automotive' started by FoundOffRoadDead, Mar 7, 2013.
  1. Mar 7, 2013 at 9:49 PM
    FoundOffRoadDead
    FoundOffRoadDead [OP] whiptastic handling
    Shamus
    Walnut
    Ford
    Alright story is this new rotors and hub's both sides along with pad's and lazier panel put on tires where straight as they could be was just done, Spacers are on the tires due to them rubbing on the spindle. Every thing is done as far as factory spec's.
    Breaks are really squishy and if i break hard then the truck shakes to a stop. the rear's lock up just fine no issues with them.
    Looking at a few things i know i need to bleed the breaks along with grease the fittings for the steering would that solve my problem or do i have to get the rotor/hub combo re-lathed in case the both of the rotor's maybe warped or off by a little?
    Any suggestions? (It is on a ford 150.)
  2. Mar 7, 2013 at 9:59 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
  3. Mar 7, 2013 at 10:29 PM
    acdronin
    acdronin Well-Known Member
    Sounds like warped rotors
  4. Mar 7, 2013 at 10:36 PM
    EFalco50
    EFalco50 Woah! How did that get here?
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Weather Tech Floor liners, AFE drop in air filter, BFG All Terrain's, Fog lights, Reese Hitch, Undercoating/Rustproofing,
    Those fords has the bearing's inside the rotor right? Could be along shot but if you say those are new rotors and they have been turned I know turning that style rotor can be a bit tricky if the tech didn't have the proper adapters for the lathe. I would check for warp that's the classic cause of shake when braking. Change your bearing's while your at it. I had someone with this problem and that fixed it, idk how but it did. Fords..
  5. Mar 7, 2013 at 10:43 PM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    All of it was new and checked at a shop :/
    Its for sale now.
  6. Dec 8, 2013 at 6:25 PM
    Tlook
    Tlook Well-Known Member
    Trey
    Charleston/Clemson, SC
    2000 SR5 4x4 over 300k miles
    3" toytech suspension lift galaxy dh33 cb, 250 watt galaxy linear amp, wilson 1000 cb antenna. 8 ball diy shift knob, led instrument cluster swap.
    prolly warped rotors. is the shaking on one side? or does it feel like its even in the front?
  7. Dec 8, 2013 at 6:26 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Wong Travur brah
    dude this thread was from march...lol
  8. Dec 8, 2013 at 6:28 PM
    Tlook
    Trey
    my bad looked at the wrong date... :smack:
