Shaking while on highway (60-65mph)
Discussion in '1st Gen. Tacomas (1995-2004)' started by STEVEO13016, Nov 21, 2016.
  1. Nov 21, 2016 at 3:15 PM
    STEVEO13016
    STEVEO13016 [OP] Well-Known Member
    STEVEO
    2000 Tacoma Prerunner V6 2WD
    5100 Billy's set at 0" with 881 coils
    Has anyone had this issue? Whenever I get my speed up to around 60-65mph, my steering wheel and front end begin to noticeably shake. I installed new 5100s and 881 coils not to long ago and it began after that. I plan on removing my sway bar to see if it helps, if not I will have my tires rebalanced.
  2. Nov 21, 2016 at 3:42 PM
    RedSki7
    RedSki7 CRF | TRD | PBR | 802
    Hollis
    Vermont
    06 AC V6 TRD OR 6sp | 02 RC 2.7L SR5 4x4 5sp
    Duck Tape, Zip Ties, & Spray Paint
    mine does this but she levels out up at 70+
  3. Nov 21, 2016 at 3:45 PM
    STEVEO13016
    STEVEO
    yeah I noticed that as well, when I hit around 70-75 it levels out.... weird? I wonder what could be causing this.
  4. Nov 21, 2016 at 3:49 PM
    Hoangde
    Hoangde Well-Known Member
  5. Nov 21, 2016 at 3:50 PM
    scocar
    scocar Patron of the Farts
    Wheel balance. You may have lost a weight or two. Putting the swaybar on won't do anything, except less sway.
  6. Nov 21, 2016 at 7:13 PM
    Tomato1981
    Tomato1981 Well-Known Member
    It could be the center carrier bearing.
  7. Nov 21, 2016 at 7:24 PM
    Roadeater
    Roadeater Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    Wheel balance or tires. Rotate your tires and drive again . I had the same problem. It was one of the front tires. Bought new tires and problem fixed.
    Of course it could be something different but it's ease to rotate and get a wheel balance done.
  8. Nov 24, 2016 at 3:48 AM
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    My truck does the same thing. Put brand new tires on it and it still does it. Had them re balanced and front end alignment. Still does it. I'm thinking maybe its a worn out steering rack.
  9. Nov 24, 2016 at 4:08 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I drive on one road I think the lower ball joints are going to fall off.
    Then I remember it is always the same part of the road
    Fine every place else
    Sicyota04 likes this.
  10. Nov 24, 2016 at 5:47 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Same here. Bought new tires stopped shaking & vibrating. But on certain parts of road it will still happen. If it's the carrier bearing you will most likely hear it.
