Shaky Taco Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by scalfee90, Apr 4, 2012.
  1. Apr 4, 2012 at 9:53 AM
    scalfee90
    scalfee90 [OP] Well-Known Member
    Shane
    Sylacauga, AL
    1999 Tacoma Manual 3.4L
    Custom skid plate, rock rails, front bumper & rear bumper, pioneer head unit with 3-way pioneer components, blinker mod, Eibach coils, Bilstein 5100s, Procomp AALs, American Racing Sawblades, M/Ts, BPV Bracket, deckplate, LED Dash
    So I'm yet another person posting on shaking at 60 to 70mph. I've actually done a lot of work trying to get it to stop but all failed.
    Balance and rotated the tires
    had alignments
    changed wheels
    new tires
    checked all driveline parts driveshaft etc.
    u joints look good
    transmission bolts are tight
    My only guess is that I need new inner axles. I also thought it might just be a good idea to rebuild the front hubs .
    if u guys have any ideas id appreciate it.
  2. Apr 5, 2012 at 6:45 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Have you checked your wheel bearings, tie rods and ball joints. How many miles are on the truck?
  3. Apr 7, 2012 at 10:52 AM
    scalfee90
    Shane
    Sylacauga, AL
    Its got right at 180,000 the driver side has a slightly bent outer tie rod and i'm orderin new ball joints. I haven't checked my wheel bearings though
  4. Apr 8, 2012 at 7:59 AM
    goomba
    Josh
    San Antonio Fl
    Well you could have messed up your inner and outter tie rod, by bending your outter tie rod. You should see if your inners are bad as well. I got moog parts from Amazon dirt cheep, and you can do the inners yourself, just have to have a huge adjustible wrench.
    Do you have any humming sounds wile you drive?(sign of bad wheel bearing) If you jack up the front of the truck and spin the wheel, if your bearing is bad, you will hear a grinding noise, and if everything is tight up front(ball joints, tire rods, ect..) hold your hands at the 12 and 6, and 9 and 3 positions and see if your tire wiggles.
  5. Apr 8, 2012 at 9:13 AM
    scalfee90
    Shane
    Sylacauga, AL
    I may go ahead and replace all my tie rods entirely just to check it off the list. I do have a giant adjustable wrench so i should be good on that one.
    as far as the humming its hard to tell over the tire noise but it does feel like i got a grinding feeling on my floorboard when i get up to higher speeds so i may check out them bearings. I'm gonna see how my tires move when i jack it up. I'll keep things posted as I go.
  6. Apr 8, 2012 at 12:52 PM
    valon5150
    valon5150 Well-Known Member
    Steven
    redding
    01 taco turd
    all pro lift, 33s, home made sliders, bumpers, skids
    check the play from your steering rack itself. May want new poly bushings. I had a shit ton of play after 15k miles on the bushings that came with my new rack. Put new bushings on it and it helped a lot
  7. Apr 8, 2012 at 2:06 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I had a lot of shake at 60mph+ until after I changed out my Rack and pinion because it was worn out...along with new outer rod ends and poly bushings....
    Rides like a caddy now :cool:
  8. Apr 8, 2012 at 2:07 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    x2
