Shark-Fin OEM antenna questions
Discussion in 'Audio & Video' started by KnurledNut, May 23, 2010.
  1. May 23, 2010 at 1:12 PM
    KnurledNut
    KnurledNut [OP] Cracker in a Taco
    Sonova Beach
    '10 PreRunner SR5
    I'm going freakin' nuts here!
    I have the Sirius equipment all wired with power. I used the SharkFin adapter from the OEM plug to the Sirius receiver. When powered up the Sirius says NO ANTENNA. So, I plugged in the magnetic antenna that came with the kit and the antenna warning goes away.
    Any ideas what I did wrong?
  2. May 23, 2010 at 3:05 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    IIRC, the stock sat antenna is for XM only...
  3. May 23, 2010 at 3:38 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Nah ... i'm using it with sirius. I didn't pay 80 dollars for the adapter however. I just spliced my antenna wires together at the kick panel and heat shrunk everything.
  4. May 23, 2010 at 3:40 PM
    The_Hodge
    SC
    hmm...that i did not know. i always saw XM related stuff and nothing about sirius
  5. May 23, 2010 at 3:50 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Technically, XM and sirius antennas operate on different frequencies but they are so close that either antenna will work, just each brands antennas will respectively have better signal quality when matched together. so i have heard.
    That being said, i have full signal on my sirius unit and get good reception with the OEM antenna. Some people say it depends on the radio (not sure why that would matter but whatever). I can't say every sirius radio will work with the oem antenna....but mine does and i have the bottom of the barrel stratus junk (aka free) radio.
  6. May 23, 2010 at 3:51 PM
    The_Hodge
    SC
    ^^that's cool. good info for everyone.
  7. Jan 19, 2013 at 6:33 PM
    Ulysiss
    Ulysiss Well-Known Member
    Ulysiss
    La Puente, SGV
    2013 Long Bed, PreRunner, TRD Sport
    im looking for a oem sharkfin antenna if any one wants to sell there or can point me to the right derection
