Sharp Intake noise when quickly pressing acceleration pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikehR, Apr 17, 2025.
  1. Apr 17, 2025 at 5:48 AM
    MikehR
    MikehR [OP] New Member
    Michael
    Bentonvillle, Arkansas
    2009 Silver Toyota Tacoma Sr5
    2 inch lift, headlights, Rear bumper
    Fellas... We may have an issue. I recently swapped spark plugs and now I have a very interesting sucking-in-air noise when I rap the gas, not at high rpm's, or repeated. It only happens during the initial press. If I am at a high rpm, and I press a significant amount more, the sound happens again. What could the issue be? I checked the tubing and couldn't find any cracks. I was thinking maybe the spark gaps? but I dont have any misfires.
  2. Apr 17, 2025 at 5:54 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I can't think of any way a spark plug change could cause an air sucking noise like you describe. I would be looking at everything in the intake path, and make sure all vacuum hoses got reconnected properly. My guess is that something got knocked loose during the change, or didn't go back together the same way.
  3. Apr 22, 2025 at 5:34 AM
    MikehR
    Michael
    I joined cuz I have a problem that needs fixing, and I was hoping I could get help.
  4. Apr 22, 2025 at 5:37 AM
    545 Well-Known Member
    2015 Access Cab
    What motor?
    Stock intake or aftermarket?
    Can you take a video and post it to YouTube?
  5. Apr 22, 2025 at 5:39 AM
    Clearwater Bill
    Billy
    Largo Florida
    The 2nd gen forum, which your truck is, may be more helpful that the general talk forum you are in.
    The plugs are unlikely to have any direct coorelation. More likely is that something removed/moved during the replacement did not get put back in place correctly.
  6. Apr 22, 2025 at 6:36 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    You have a throttle plate issue.
    The only way to fix it is to jam the accelerator to the floor, and potentially scream WEEEEEEEEEE!!!! As the truck rockets off to mars. At least until the fuel runs out.
    In all reality, nothing is wrong with your vehicle, it's just part of how internal combustion engines moderate their speed. By managing the amount of air entering the combustion chamber.
    It's also how vehicle vacuum pressure is created.
  7. Apr 22, 2025 at 7:29 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Did you remove the intake manifold or anything other than the coils and plugs?
  8. Apr 23, 2025 at 5:14 AM
    HWI
    HWI Well-Known Member
    North Florida
    2015 Tacoma TRD Off Road
    Did you remove the intake when you changed the passenger side plugs and maybe didn't fully reseat it? Not sure that would cause the noise you're hearing, just a shot in the dark.
