Sharp turns in 2wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dawgrules, Mar 9, 2020.
  1. Mar 9, 2020 at 3:30 PM
    dawgrules
    dawgrules [OP] Active Member
    2012 DC 4x4 MT when making sharp turns on pavement, like pulling into a parking space, the truck "chatters" and chirps almost as if in 4wd. You can feel every knob of the 285 mud terrains as they roll, and it (or an alignment issue) is starting to take a toll on the front tires...So, I confirmed the ADD is operating by spinning the front tires by hand in 2wd and 4wd. No problem there, it responds as expected, and the truck shifts in and out of 4wd, no problem. So I am wondering about CV joints (the are no other symptoms) or is maybe the nature of big lugged tires? All my prior experience has been with more docile all terrains
    TIA
  2. Mar 9, 2020 at 3:32 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    nature of big lug tires id imagine. Also, what are your alignment numbers?
    Dagosa likes this.
  3. Mar 9, 2020 at 3:40 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Definitely sounds like alignment to me.
  4. Mar 9, 2020 at 3:45 PM
    Taco Roofer
    Taco Roofer Well-Known Member
    Noah
    Southern Oregon
    2004 Tacoma 4dr 4x4
    The work beast and weekend warrior rig.
    My 'big lug' 285's don't chatter at all... smooth as butter ride and steering. Better take it to an alignment shop
  5. Mar 9, 2020 at 4:07 PM
    dawgrules
    The truck is lined up, if not precicely to spec, very, very close. Drives straight as an arrow and no asymmetrical tire wear
  6. Mar 9, 2020 at 4:11 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    It's the tires. My KO2's never did this. The POS Duratracs do this on every sharp turn.
  7. Mar 10, 2020 at 6:44 AM
    Taco Roofer
    Noah
    Southern Oregon
    2004 Tacoma 4dr 4x4
    The reason I suggested an alignment shop is that then you can have a professional and yourself get under the truck easy and inspect it. Maybe it is a cv problem? Maybe it's something else? Wheel bearing perhaps?
    I've run all kinds of mud terrains and the only ones I've ever heard chatter because of the tire were brand new bloggers, even those mellow out once they have some wear on them.
    I have had trucks that might have been aligned perfectly but they had some parts going bad and needed to be replaced.
    Best of luck, these things can be a pita to track down, hopefully it's not.
    0xDEADBEEF likes this.
  8. Mar 10, 2020 at 2:27 PM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Agree. It definitely appears to be a tire and/ or alignment problem.
