Shauncho's "Who knows where this is going?" Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Shauncho, Sep 30, 2012.
  1. Oct 18, 2013 at 6:58 PM
    #101
    Jake1025
    Jake1025 Active Member
    Jake
    Tampa
    12 TRD PreRunner
    Bought some Satin black , and 3m window weld. Followed your steps and the bumper grille and headlights came out fairly easy. Found out the oven was too small to fit my headlight in :| So I fought with it. Chipped up the edges with a flat head trying to get it off blow dryer style. No luck. Just gonna get everything reassembled in the morning. No time lost though. Was a fun project to do with my dad up until the oven issue.
  2. Oct 18, 2013 at 9:01 PM
    #102
    Shauncho
    Shauncho [OP] Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    Sorry to hear about the oven issue. Glad you had fun with it anyway though! :thumbsup:
  3. Oct 20, 2013 at 7:07 PM
    #103
    Shauncho
    Shaun
    Parts Unknown...
    none
    sooooo I got bored this weekend and broke out the spray gun...My badges and wheels put up a good fight but in the end my spray gun prevailed. Only problem is it's kinda one of those "good from far" things. I painted my lugs and as expected the lugs chipped a little as I tried to lock them down. I also started to run out of time and had to put the rear wheels back on before they were fully dry. But honestly, most of that stuff you can't really see unless you really look. Otherwise, it was well worth the endeavor and I'm really happy with the end result.
    I wrote this up for a member asking about my process and I figured might as well post this info here too.
    My Process:
    • Washed wheels well/Dried wheels
    • Took off center caps and removed the Toyota logos from them using needle nose pliers. To get the center caps off, just knock them from the back side with the handle end of a hammer or something like that. When you look at the back of the center caps you'll know exactly what to do with the Toyota logo. Both of these I lightly roughed up with 220 grit then smoothed that out with 2000 grit.
    • Mark where the balancing weights on the outside of the wheels go using tape and then pry those off (not sure the best way to do this but I just used a flathead screwdriver...you will have little nicks in the finish doing it this way). You only really need to do the outsides but if you want to you can do the same for the ones on the inside... I didnt.
    • Sanded the wheels with the ScotchBrite Heavy Duty scrubber pads. The Sport wheels have some sort of a clear coat on them so I figured these were good enough to rough it up a little. I got this idea from another TW member.
    • Masked everything off and sprayed the back of the wheels. I did the backs first that way I could flip them over and do the fronts as the backs were drying. Probably works the other way as well but since the backs set inside the tire so much I knew I could flip them and not mess up the insides.
      NOTES:
    • Most importantly, have a clean, dust-free place to do this. I didn't and it was HELL making them look even remotely decent. It only takes a few minutes to setup a quick spray booth in a garage with plastic drop cloths...just make sure you have some sort of ventilation and a respirator.
    • If you use the same paint I did, it is not water-based which means clean up is a BIATCH! Prepare accordingly. Rubber gloves are cheap, use a lot of them. :D You'll also need paint thinner or acetone.
    • If you do use spray paint, you can't shake them enough. When you think you've shaken them enough, shake them another 20-30 seconds. It'll help avoid fucking up your finish when applying later coats. (some people know this, some people don't...I'm not assuming you don't but just playing it safe)
    • I didn't have time to prime otherwise I would have liked to.
    • I definitely recommend having 4 jack stands so you can remove all 4 wheels at the same time. Took a lot longer for me to do two at a time than it could have.
    • As for the lug nuts, I painted these with spray paint...I wouldn't recommend it. They look good from far but up close they're all chipped up. There's really no good way to do this with red lugs other than buying red anodized but I was only able to find those in a certain shade of red that didn't go with the other red I was using. Harbor Freight has a that has pretty good reviews....and you could then just cure the lugs in your own oven at home...I may try this just because it'd be awesome to have a powder coater!
    So I got this idea for the Tacoma on the tailgate from another member whose name I can't remember. It was quite a fun project; cutting apart the letters, sanding down the connectors and prepping the letters for paint. The end result was totally worth it. The paint on the letters look spectacular!
    I'm so glad those toyota emblems come off! Made for an easier time painting. Love how they turned out.
    I got this idea from seeing someone with a red emblem and I liked the effect the black had behind it...so I did the reverse and painted the grill red. This is another one of those "good from far" things so don't come too close! :)
    and that reflection in the bottom of the wheel right there is why I chose satin. It gives what I call the "creamy" gloss look which I love. Even though I rushed it and screwed some things up, I'm still pretty happy with how it looks...but keep your distance! :)
  4. Oct 29, 2013 at 8:00 AM
    #104
    Shauncho
    Shaun
    Parts Unknown...
    none
    So...Marty might have just become an official Mall Crawler...at least for now. My wife knew I wanted a project vehicle with 4wd since Marty is only 2wd. So for my birthday she bought me a '99 4Runner 4x4!! Can't wait to get it and start modding it. I'll eventually create a separate build thread for it. For now, I'm just trying to figure out what I want to do with it. Then it's time to start researching some parts. My wallet is feeling lighter already! :D
  5. Nov 22, 2013 at 10:51 AM
    #105
    Shauncho
    Shaun
    Parts Unknown...
    none
    Dear Secret Santa,
    sorry, I know I don't have a ton of info about what I want or am into...I'll work on that. But whatever you end up getting me I'm sure I'll love it! :D
    Things that I can remember talking about recently that I already have now:
    Ultragauge
    Harbor Freight powder coating system
    nfab tube steps
    BAMF light bar mount
    will be soon ordering a 20" LED light bar.
    Shauncho
  6. Nov 23, 2013 at 10:58 PM
    #106
    Traction120
    Traction120 "Not all those who wander are lost"
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    If you ever want to swap hoods, just give me a shout lol.:p;)
  7. Nov 24, 2013 at 7:13 AM
    #107
    Twinkie0311
    Twinkie0311 Mall crawling like a boss
    Hillsboro, Oregon
    13 DCLB TRD Sport MGM
    OME Lift w/ Dakars, TRD catback exhaust, 275/70/17 with SCS Stealth 6. and much more.
    Truck looks pretty sick man. Glad to see another DCLB being fixed up on here. Really like that Tacoma lettering in the back looks real mean.
  8. Nov 25, 2013 at 6:00 AM
    #108
    Shauncho
    Shaun
    Parts Unknown...
    none
    Hahaha, I've definitely thought about it because of the gnarly glare it gives off but I love the way it looks. If that for some reason ever changes I'll let you know! :D
  9. Nov 25, 2013 at 6:01 AM
    #109
    Shauncho
    Shaun
    Parts Unknown...
    none
    Thanks man! :thumbsup:
  10. Dec 4, 2013 at 10:38 AM
    #110
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Good job on the grill emblem and tacoma emblem on the tailgate! I like it.
  11. Dec 4, 2013 at 10:38 AM
    #111
    Shauncho
    Shaun
    Parts Unknown...
    none
    Thanks, man! :)
  12. Dec 5, 2013 at 8:12 PM
    #112
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Haha! I definitely didn't see this post, before I picked out your gift. Let me know if you have any issues with anything.
  13. Dec 5, 2013 at 8:25 PM
    #113
    Shauncho
    Shaun
    Parts Unknown...
    none
    dude, no issues with ANYTHING you go me!! I love it all!! Thanks so much. This gift is perfect for me! I already installed the dome light tonight and I love it. Can't wait to get to use the fire starter next camping trip! Hell, I might even use it for my fire pit tonight!
    Thanks again, dude!! :thumbsup: you ROCK!
  14. Dec 6, 2013 at 6:30 AM
    #114
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    You are welcome!
  15. Dec 6, 2013 at 8:24 AM
    #115
    Shauncho
    Shaun
    Parts Unknown...
    none
    Well, as you can all see, my awesome Secret Santa, Peter (LoadedTaco) got me some LED lights for Marty! I'll take better pics later but here's a couple. What a difference!
    Dome light before
    Dome light after
    With all LED map and dome lights on
  16. Dec 20, 2013 at 1:57 PM
    #116
    Shauncho
    Shaun
    Parts Unknown...
    none
    FFFFFFUUUUUUUUUUUUUUUUUUUCCCCKKKKKKK I WANT FUCKING MODS!!!! GAAAAAAHHHH :goingcrazy:
  17. Dec 20, 2013 at 1:59 PM
    #117
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    8y4emaze_225601f3a0d6f491374378caf2be38f63a7a348c.jpg should do a retrofit. They look so nice
  18. Dec 20, 2013 at 2:07 PM
    #118
    Shauncho
    Shaun
    Parts Unknown...
    none
    yeah, I'm definitely thinking retrofit at some point. Just gotta save up a little. Christmas has wiped me out!
  19. Dec 20, 2013 at 2:10 PM
    #119
    Twinkie0311
    Hillsboro, Oregon
    new baby has wiped me out man. i feel your pain
  20. Dec 20, 2013 at 2:10 PM
    #120
    Shauncho
    Shaun
    Parts Unknown...
    none
    Fuck it, while I'm bored and driving myself crazy thinking of mods (if anyone is actually reading this).
    What mod do YOU think I should do next?
