shaving bumps
Discussion in 'Off-Topic Discussion' started by 1998tacomaowner, Nov 27, 2011.
  1. Nov 27, 2011 at 12:14 AM
    1998tacomaowner
    1998tacomaowner [OP] Well-Known Member
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    Every time I shave I get shaving bumps on my neck I use Gillette fusion shaver and cream anyone have the same issue and what have you done to solve it?
  2. Nov 27, 2011 at 12:15 AM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    How are you shaving, direction?
  3. Nov 27, 2011 at 12:15 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    I had the same issue when I shaved "down" on the neck....switched to shaving "up" and haven't had them in years.
  4. Nov 27, 2011 at 12:22 AM
    Tigahshark
    Isaac
    You could also switch back and forth from your shaver to a electric shaver to give your skin a break from time to time.
  5. Nov 27, 2011 at 12:24 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    electric shavers tear my face up for some reason, i can't use em
  6. Nov 27, 2011 at 12:26 AM
    Tigahshark
    Isaac
    Wow, never heard of that before but i guess every guys skin is different
  7. Nov 27, 2011 at 12:26 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Make sure you first have your facial hair warmed up either by shaving after a hot shower, or placing a hot wet rag on your face for a few moments.
    Then apply beard conditioner or shaving oil to prep your facial hair for shaving.
    Use a quality shave cream or shaving paste, shave first with the grain cleaning the blade with hot water frequently, then re-lather and shave against the grain if necessary.
    Cleans your face with cold water to tighten your skin, pat dry, then apply an after shave and a quality moisturizer.
    I prefer using Jack Black products for shaving which you can pick up at any Nordstrom.
    I use a Gillette Fusion pro everyday changing the blade every 3 days, and a straight razor on Sundays. It's just getting expensive to replace the shave cartridges.
    I'm planning on switching to a quality Merkur reusable razor. It gives a great shave, and its $30 for the razor, the blades are cheap. A year supply of razor blades is under $20.
  8. Nov 27, 2011 at 12:32 AM
    Joe D
    Joe D .
    Wow, well detailed. I've not put that much thought into...anything I can remember.
  9. Nov 27, 2011 at 12:33 AM
    Warputer
    2011 TRD Off Road
    :rofl:Damn you guys crack me up!
  10. Nov 27, 2011 at 12:34 AM
    1998tacomaowner
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    I will have to try shaving up
  11. Nov 27, 2011 at 2:02 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I hardly ever shave. Probably solved. :D
  12. Nov 27, 2011 at 2:10 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Werd! isn't this movember month and junk??
  13. Nov 27, 2011 at 2:23 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Ditch the Fusion. Go with a solid double edge razor. Get a good badger hair brush (I like Best Badger). This will help exfoliate your skin. Some good cream and your set. No need to use pre shave oil IMO.
    My setup us a Muhir R89, Edwin Jagger Best Badget hair brush and Avocado oil shaving cream by Taylor of Old Bond St.
    I do two passes. Best shave I ever had and my skin is fantastic after. Wife loves it.
  14. Nov 27, 2011 at 2:48 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    I have the same problem
    I also get the same random bumps, not many but a couple each time, I'll try shaving up and see what happens
  15. Nov 27, 2011 at 3:21 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    I'm the same way with electrics. Even the best irritated my skin to no end. I use a double edge razor for my head and my face. New blades are $1.79 for 10 blades so I just use a new one every time I shave, which ideally is every day or two. I've tried creams, gels, and oils and found shaving oils to give the best, closest shave with the least cuts so I would assume the least irritation for those who are prone for it.
  16. Nov 27, 2011 at 4:07 AM
    Joe D
    Joe D .
    Is it wrong that I now have and un-expected chub?
  17. Nov 27, 2011 at 4:21 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I have been using a quality double edged razor for over 30 years...and I change blades every six weeks or so. Not that I'm cheap...
  18. Nov 27, 2011 at 6:02 PM
    Warputer
    2011 TRD Off Road
    Well? How'd it work out for u's guys?
  19. Nov 27, 2011 at 7:11 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    I had the same problem and only thing I did different was use conditioner for shaving cream, much smoother now
  20. Nov 27, 2011 at 7:26 PM
    FrankNasti
    FrankNasti Well-Known Member
    Frank
    Anywhere the Army tells my wife to go.
    Subaru Forester
    The toddler and baby seat mod.
