Shaving with straight razors
Discussion in 'Sports, Hobbies & Interests' started by crazyengineer, May 2, 2011.
  1. Oct 4, 2011 at 8:39 PM
    #41
    crazyengineer
    crazyengineer [OP] Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    anything made in america, germany, England
    avoid pakistani and china crap
    if you find a japanese straight (which is a different style) they are nice too, i want one
    just dont get anything too big or too small (blade height), middle of the road is a good one
    antique shops are good sources
    Check out the forums over at straightrazorplace.com, they can send you in the right direction for everything, they are friendly to new comers from what i have seen
    your better off building one yourself, check out the website i recommended above, they can help you a lot
  2. Oct 4, 2011 at 8:42 PM
    #42
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    thanks, I may start looking around then.
  3. Oct 4, 2011 at 8:56 PM
    #43
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
  4. Oct 4, 2011 at 9:07 PM
    #44
    crazyengineer
    patrick
    Bristol, TN
    i seriously doubt it will work at all, if it does, it is only on cloth, i doubt on a stone...s because of the sides for the razor
    again, i would recomedn this at all
    and if your stone is very very fine,it would probably lead to irritation only
  5. Oct 4, 2011 at 9:10 PM
    #45
    jrgroucho
    jrgroucho Well-Known Member
    Jeremy
    Michigan
    2010 AC SR5 BSP
    Hose Clamp, No Seatbelt Chime, Husky Floor Liners, BHLM, sockmonkey Tailgate Decal, Wet Okole Covers/Armrests,
    I normally shave with a DE razor, I have close to three dozen. talk about RAD. (I also have enough blades to last for the the nest 25 years :eek:.)
    I also have a Japanese style Feather that takes disposable blades. I use it when I have a few extra minutes or am going somewhere important.
    As for cutting off my head, the learning curve isn't as steep as most think.
    I recommend a good brush/blade/cream for anyone that that can't get a good shave or breaks out. I could never get a clean shave with multi-blade razors, but I never break out with the old style stuff.
  6. Oct 4, 2011 at 9:11 PM
    #46
    Tacomanator
    Clam Slammer
    Southern Cali
    Cool thanks.
    Gonna try the jean thing right now.
  7. Oct 4, 2011 at 9:14 PM
    #47
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Sub'd
  8. Oct 4, 2011 at 9:29 PM
    #48
    crazyengineer
    patrick
    Bristol, TN
    i wouldnt get your hopes up
  9. Oct 4, 2011 at 9:33 PM
    #49
    crazyengineer
    patrick
    Bristol, TN
    you sound like me....RAD is very very strong......
    What is your DE set up?
    i use an older gillette adjustable right now since i am in the dorms (will change soon)
    i used to rock a gillett fatboy...until i found something better
    ditto to the break outs, i get less when i shave more often with the soap and brush.
  10. Oct 4, 2011 at 9:56 PM
    #50
    futuretacoowner
    futuretacoowner Well-Known Member
    Andrew
    Canada
    02 2.7L xtra cab
    I want to so bad, but can't find any around here.
  11. Oct 4, 2011 at 10:00 PM
    #51
    crazyengineer
    patrick
    Bristol, TN
    Where have you looked for razors at?
    Where are you located in Canada?
  12. Oct 4, 2011 at 10:04 PM
    #52
    futuretacoowner
    Andrew
    Canada
    02 2.7L xtra cab
    I looked at a few blade and hairdresser shops (weird combo I can get an 8'' santoku knife and a blowdryer at the same boutique store. I am in New Brunswick, I really have been floating around the province alot.
  13. Oct 4, 2011 at 10:05 PM
    #53
    Tacomanator
    Clam Slammer
    Southern Cali
    Well, I just got done trying the jean method and I gotta say, i'm sold. I used it on an old razor thats been sitting in my drawer for many months (Schick Hydro 5). The razor glides accross my face almost as smooth as a fresh razor, no tugging or pulling. I even shaved against the grain with no problem, no nicks, cuts, irritation or burning afterwards. And I was well do for a shave (was going on 5 days w/o one).
    I suggest giving it a try, it's so easy to do and if it doesn't work for you, just grab a fresh razor and continue shaving.
  14. Oct 4, 2011 at 10:07 PM
    #54
    crazyengineer
    patrick
    Bristol, TN
    look in antique shops, thats where i have found all mine
    flea markets work well too, i have seen a lot, just havent bought any......yet
    just do a bit of research first so that you know what brands are good and what brands to avoid
  15. Oct 4, 2011 at 10:09 PM
    #55
    crazyengineer
    patrick
    Bristol, TN
    cool that it worked, but if the tips of the blades ever roll inward you may not be able to do that again, you are essentially stropping them, but you are only stropping one side of the blade. I may actually try this, event though i dont multi blades, just because i am curious now....
  16. Oct 4, 2011 at 10:13 PM
    #56
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    i rarely am clean shaven. just kind of rock the tom cruise scruffy look. about twice a week ill use my pube trim. . ah . . i mean electric razor extension arm to knock it down, but shaving's just a hassle and gives me razor burn. :(
  17. Oct 5, 2011 at 6:41 AM
    #57
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I shaved in the Rig Camps and actually I didn't get too many double takes at all. But it's gang showers so generally people keep to themselves.
    You can find Dovo Razors on Ebay. They'll start around $100, but they'll be shave ready right out of the tin/box and they are quality. Don't buy the most expensive brush you can find, I got a Vie-long Horse hair brush and it works very very well for me. It was only $15-20, Proraso shaving soap (Really nice stuff, will wake you up better than coffee, Super refreshing.) $10. And that's all you really need. Strop buy a new one from here that will do just perfectly.
    http://www.whippeddog.com/
    or www.theartofshaving.com
    Just remember, if you're straight shaving or Double edge shaving you're doing it to enjoy the act of shaving. It isn't something to be rushed. It's to take 10-30 minutes out of your day for yourself. Attempting to pound out a shave 5 minutes before work will make it looked like you attempted oral sex with a pair of windup chatter teeth to a badger.
    Also, Alumblocks are worth their weight in gold. However Crystal deoderant is the exact same thing and sells for the same or less. And you can find it in pretty much any grocery store. Eliminates pretty much all razor burn (It till burn a little when you first put it on, but that's what it does.) and it helps close up any little nicks you have when shaving.
    After I straight shave, my face literally feels as soft as my wife's. (Which she loves.)
    It works.
    I live in Canada. Lies lies lies. You just have to know where to look.
    Calgary based store. I'm not fond of the straights he carries personally, but the rest of his stuff is quality. (Not to say his razors aren't quality because they are; they're just not my style.)
    #57
  18. Oct 5, 2011 at 7:03 AM
    #58
    jrgroucho
    Jeremy
    Michigan
    2010 AC SR5 BSP
    Right now, I'm mostly using a 1951 Gillette Black tip SS. I have a Fatboy, but rarely use it; I never got a great shave out of it. I should try it again, as it's been a few years.
    I agree with Krazie, take the time and enjoy your shave. As someone who didn't know how to shave and always ended up with a bloddy mess, I can say that DE and single blade razors made me enjoy shaving.
    And believe me, girls love the result. They also think using those all metal razors is pretty manly. ;)
  19. Oct 5, 2011 at 7:15 AM
    #59
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    It's all about the Razor Acquisition Disorder. :p
    I've actually cut myself off from getting anymore right now, cause I went on a bit of a spree. I also got a Norton 4K/8K honing stone and I brought one razor back from destruction very nicely. (My Hugo Koller, couldn't cut skin before, now it passes the HHT effortlessly.)
    Really? I got a wicked shave from my fatboy. My face is pretty forgiving with regards to shaving. Only place I have issues is my jaw line...and only on the right hand side...and only when using my straight razors. So it's obviously a technique issue. I can have my Fatboy dialed open to the max and it's good to go. I was looking at this bad boy though.
    Merkur Satin. :drool:
  20. Oct 5, 2011 at 7:31 AM
    #60
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    I agree. I use titanium blades now.
    The carbon steel blade isn't really getting dull, it's rusting. The jeans trick is trying to mimic stropping, but denim isn't the proper material to do that with.
    A box of 4 lasts me a year. I'm good with that.
