She served me well!! Engine build guidence
Discussion in '4 Cylinder' started by Bluefin3366, Mar 25, 2015.
  1. Mar 25, 2015 at 1:28 PM
    Bluefin3366
    Bluefin3366 [OP] New Member
    Roger
    Ventura
    Tacoma
    After almost 18 years and 280K miles later, she's finally needing a new motor.
    Should I go re-manufactured or have mine rebuilt?
    I live in LA and any advise would be appreciated.
  2. Mar 25, 2015 at 2:02 PM
    Speedytech7
    3435 E Trent Ave, Spokane, WA 99202
    It's less Tacoma and more mod
    Which motor? 2.4L, 2.7L, or 3.4L, cause of death (need to know if rebuilding is worth it), what you use the vehicle for? All those can help determine what will pay out best.
    Welcome to TW! :)
  3. Mar 26, 2015 at 9:12 AM
    Bluefin3366
    Roger
    Ventura
    Tacoma
    2.7L
    Oil found in the cylinder
    used as a daily driver
  4. Mar 26, 2015 at 6:04 PM
    Speedytech7
    Hmm, I would rebuild as it sounds like worn out rings or bad valve stem seals.
  5. Mar 27, 2015 at 8:04 AM
    muliefever
    muliefever Muliefever
    Tillamook, Oregon
    14' DCSB TRD
    5100's, 887', CB, 265's, FM Deltaflow
    rebuilding is easy. Just make sure you do NOT re use the factory chain tensioner. Mine just failed after my rebuild.. All is well now
  6. Mar 27, 2015 at 9:29 AM
    Speedytech7
    I was following your thread, glad to hear everything turned out fine. Did you come to a conclusion as to whether the 3RZ-FE is an interference or non interference engine?
  7. Apr 6, 2015 at 3:49 AM
    scootn2nature
    scootn2nature ttora member since 2001
    orinda
    2000 2.7l sr5
    bentup sliders, tjm t17, badland rear,custom leafsprings, fabtech performance co's,
    3rzfe is an interference
  8. Apr 6, 2015 at 5:18 AM
    Clearwater Bill
    Billy
    Largo Florida
    That comment, as it stands, does not justify either a new motor or even a full rebuild.
    I'm not saying one isn't needed.
    Just asking about the rest of the diagnostics. There has to be more to the story.............
  9. May 15, 2015 at 1:45 PM
    Jarlaxle
    Jarlaxle Well-Known Member
    New England
    Not a Tacoma yet...
    Might just need valve seals...
