SHE STILL SHAKES!!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by CamShaft223, Dec 18, 2015.
  1. Dec 18, 2015 at 1:36 PM
    CamShaft223
    CamShaft223 [OP] Member
    95 Tacoma SR5 4x4 5 speed
    K&N intake, 3 inch lift
    Hi im new to the forum and dont feel like typing correctly because it takes too long for me.
    I have a 95 Tacoma. its the 5 speed Manuel transmission. 3.4 L V6 blah blah blah. The only upgrades it has is a K&N intake and 3 inch lift and after market wheels.
    She shakes. between 45 and 60 she shakes. At any speed, if i let completely off the gas, she shakes. If im really laying the fuel to her she quits shaking. This truck has been this way since i bought it. ive put over 20k miles on it and nothing has changed. I bought it with the stock wheels and just recently got the ever so common Dick Cepeck wheels, she still shook.
    I even lowered my drive shaft carrier bearing to try and fix it, nothing.
    What gets me is, I just paid a $1463 shop bill. thinking it was gonna fix my shake.
    this price included
    Steering rack
    Rear axel seal
    Rear brakes
    Gear oil
    Valve cover gasket
    PCV valve
    Timing belt
    Both new front axels
    oil seal
    And an alignment
    Ive heard its just the nature of the tacoma. But really, is there anything else i can do for this thing?
    Thanks. Cam
  2. Dec 18, 2015 at 1:41 PM
    Madjik_Man
    Colorado Front Range
    Most of that work is just routine maintenance. Assuming the "blah blah blah" portion of your post is speaking to how many miles are on the truck, that sounds like solid routine maintenance.
    One question: are your wheels/tires balanced?
    It could also be u-joints or the carrier bearing
  3. Dec 18, 2015 at 1:55 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    My vote is a bad u-joint in rear axle.
  4. Dec 18, 2015 at 1:55 PM
    oldschoolbmx
    oldschoolbmx Well-Known Member
    Harry
    02' Tacoma TRD, 14' T4R SR5, 17' Tundra CM Ltd
    Magnaflow cat-back, K&N, B&M short shifter
    Mine shakes too. 02 Ext cab 4x4 V6. I think it's my carrier bearing as I have tons of play. I plan on replacing mine between xmas and new years since I'm off anyway. Probably gonna replace front and rear u-joints while I'm in there.
  5. Dec 18, 2015 at 2:01 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Does it get better while in.4x4? Sounds driveline related to me.
  6. Dec 18, 2015 at 3:08 PM
    CamShaft223
    Roughly a year ago I replaced the carrier. Didnt change anything. Never tried the universals, although they felt tight when i did the carrier. And the tires, I had them balanced at the local shop, have no idea what all they did with them. And thanks for the replies so quickly
  7. Dec 18, 2015 at 3:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    When I had a vib like that it was caused by too high of CV axle angles. Lowering the axle angles eliminated the vib.
    You mentioned having a 3" lift and having to replace your CVs. Had the boots failed?
    Got any pics that show your front axles?
  8. Dec 18, 2015 at 3:16 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    You should check the ujoints. Shaking between 45 and 60 is classic ujoint/driveline out of balance. One way to know for sure is to get in on a car lift, take the wheels off and run the driveline to the speed to where it shakes. If it still shakes, check the driveline with a dial indicator and a magnetic base for wobble.
  9. Dec 18, 2015 at 3:17 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Have you checked the bed?
    You could have one of these in there. :rolleyes:
  10. Dec 18, 2015 at 3:32 PM
    CamShaft223
    haha. Toyota's are known to have those.
  11. Dec 18, 2015 at 3:36 PM
    CamShaft223
    And yes. the boots have failed. And I dont have any pictures. Would lowering the angle affect the castor alignment?
  12. Dec 18, 2015 at 3:41 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Nope. Axles and diff are independent of spindles. Do a diff drop to lower the angle of CV joints.
    Have you checked the ball joints?
  13. Dec 18, 2015 at 3:56 PM
    CamShaft223
    Ok, and yes, balljonts are good. That could definitely be it. How do you lower that though. I dont really want to go outside with a flash light and lay on the cold wet ground at the moment, haha. I do understand though.
  14. Dec 18, 2015 at 4:00 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    After 20K miles - did you get and wear patterns on the tires?
  15. Dec 18, 2015 at 4:07 PM
    CamShaft223
    No wear patterns, that are worth mentioning really
  16. Dec 18, 2015 at 4:09 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I couldn't get rid of the vibration between 50mph - 70mph and it took 3 different times to finally get it balanced on some machine the tire shop had. They would balance it a little bit, take it for a drive them do some more balancing and they would take it for a drive again they even let the air out of the tires and aired them up again and let it mount better or seal better to the rims. Finally whatever they did it rides perfect now. No more vibration. One thing I didn't have to do is replace any parts.
  17. Dec 18, 2015 at 4:15 PM
    Canufixit
    New England
    Did you try taking the drive shaft out and running in 4wd (front wheel drive only?) and then again do the same thing to the front?
    When you get the shakes - did you put it in neutral shut off the engine and let it coast??
  18. Dec 18, 2015 at 4:24 PM
    CamShaft223
    I did not try any of those things Canufixit. It is more of a vibration, as people are saying. It does feel like off balanced wheels, but it felt exactly the same after i got my after market wheels and had them balanced. so ive judged tire balance out. I think the next thing i do is check u-joints again and what Gigiratus said about the front end.
  19. Dec 18, 2015 at 4:45 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Are you manual hubs?? If so then you can rule out any thing as far as cv joint and diff drop stuff. Now if youre ADD then of course these things would play a role. Id recomend a diff drop aswell in this case. But....since youre losing your vibes on decel and feeling them on acceleration it really sounds like a u joint. Sometimes its really hard to tell if one is bad by trying to shake and move the driveline around. It dosent take much for one to begin to develope a slight whobble.
  20. Dec 18, 2015 at 5:15 PM
    CamShaft223
    No its worse on the decel, stops when accelerating. And they are automatic hubs
