Sheared screws on my Prinsu Rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Georgeth1022, Nov 2, 2021.
  1. Nov 2, 2021 at 9:39 PM
    Georgeth1022
    Georgeth1022 [OP] Well-Known Member
    Shaun
    West Hills CA
    2013 BAJA w/ too many mods
    Too many to list
    So I apparently overtightened a couple of the screws on the crossbars on my Prinsu rack. Or they seamed to rust in place, or a combo of both. When I went to remove the screws, the bolt sheared off. Any good ideas, tips, tricks to get the threaded part out of the rail??
  2. Nov 2, 2021 at 10:25 PM
    Waasheem
    Waasheem
    2007 xrunner
    When you say screws, we talking the self threading type or a threaded screw going into a threaded hole? If threaded, it’ll be easier to extract. If it’s a tiny diameter, tricky.
    Saturate with plenty of wd40 or on pb blaster to help with the rust.
  3. Nov 2, 2021 at 10:52 PM
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    This is the problem with dissimilar metals especially aluminum and stainless steel. The aluminum most likely expanded due to corrosion and is gonna be a SOB to get out. If it was me I would undo all the screws I could. Spread the sides of the Prinsu rack out and remove the cross bar. Heat and beat with a hammer to loosen bolts and hopefully there is enough room to get vise grips on the broken off heads threads.
    Then put Cadium Plated Hardware back in. https://www.mcmaster.com/bolts/fini...y-navy-medium-strength-steel-hex-head-screws/
    mtip, Gunshot-6A and TartanEagle like this.
  4. Nov 2, 2021 at 11:16 PM
    Georgeth1022
    Shaun
    West Hills CA
    Too many to list
    So no the screws are smaller, not tiny tho. I was thinking of removing the rail, the soaking with PB. Then, if there is anything sticking out past flush, try vice grips. If not, use a Dremel cutting wheel to make a slot for a flat head screwdriver, and try carefully unscrewing.
    bagleboy likes this.
  5. Nov 3, 2021 at 3:12 AM
    Chappa
    Chappa Well-Known Member
    Philadelphia
    2015 DCSB TRD OR
  6. Nov 3, 2021 at 3:49 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
  7. Nov 3, 2021 at 4:37 AM
    Waasheem
    Waasheem
    2007 xrunner
    Third, this type of extractor works well on smaller screws. You might need to clean the penetrant off where the extractor contacts the screw to get it to grab.
    There’s a tool called vampliers. They’re not cheap but work very well, instead of vice grips.
    Gunshot-6A likes this.
  8. Nov 3, 2021 at 7:56 AM
    acdubstaco
    acdubstaco Well-Known Member
    Adam
    NorCal
    2011 TRD OR
    I just did this a few weeks ago. Seems like those bolts are pretty brittle! I removed the crossbar from the rail and was able to get some vice grips on what little thread was left. I was lucky and I was able to get them out without too much fuss. Good luck!
  9. May 14, 2022 at 12:34 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Just figured I'd pop into this thread since I'm having the same problem. Bought a nearly new Prinsu from an acquaintance and he put the cross bars in non-standard positions. When I went to move them I snapped the heads off 5-10 of the bolts on 3 different cross bars. I managed to get one, maybe two of the snapped screws out of the cross bars but the others are stuck. Been soaking them in PB blaster for weeks in the garage.
    Tried that SpeedOut kit - what a waste of money. I'd used similar years with ZERO luck but went out and bought a kit based on the recommendations in this thread. Figured I maybe just had a bad experience or had a bad brand back then. Nope. These are just garbage. Maybe they work for non-seized screws that just have mangled heads but I don't see them working at all for anything where the bolt is actually seized or broken. Waste of money if you ask me.
    Looks like I'll just be replacing the cross bars as I don't think there's going to be any way to get these out I may try drilling them out fully and seeing if I can save the threads with a tap but it's pretty unlikely to work I think. Gotta order an SAE tap set though as I only have metric. Speaking of which, I really hate when companies use SAE hardware for stuff like this, everything should be metric! lol
    fatfurious2 likes this.
  10. May 14, 2022 at 12:54 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    I would use a small enough drill bit to remove enough of the screw to where you can break the rest of it up without damaging the threads in the crossbar.
  11. May 14, 2022 at 1:55 PM
    clenkeit
    Colin
    Lakewood, CA
    I've drilled two out this way and so far, it looks like this isn't going to work. First off, it's super hard to get your hold DEAD center of the screw. Second, the metals are seized/corroded so even after drilling out the center of the screw the remaining screw material does not want to dislodge from the crossbar.
  12. May 14, 2022 at 1:58 PM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
  13. May 14, 2022 at 2:54 PM
    clenkeit
    Colin
    Lakewood, CA
  14. May 22, 2022 at 7:59 AM
    rogair
    rogair Member
    AB, CAN
    2013 DCLB
    5100 front, 885, Dakar HD, B110, Timbren Off-road
    Just went through this. I drilled the snapped bolts and re-tapped with 1/4-20. Got lucky without trashing it up but it took a while. Broke an Irwin spiral extractor trying to extract them out so I moved to drilling it completely. Might be worth it to just replace the bars.
  15. May 22, 2022 at 8:04 AM
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    If you bought it new they are cover for as long as you are the original owner, I just had 6 new ones sent to me last month . They did say use purple thread lock to keep water out and keep the screws from rusting
  16. May 22, 2022 at 7:55 PM
    clenkeit
    Colin
    Lakewood, CA
    I did actually buy replacements already. TNutz was having a sale so I picked some up assuming I likely wouldn’t be able to repair all of mine. But, figured I’d at least try to fix em. That way I’d have extras or material to make something else perhaps.
    I’m gonna order a tap but so far I don’t think my drilling ability is up to par to make it work. So far I haven’t been able to get dead center on the old bolt.
    I now understand why they say to use thread locker. I wish the instructions stated it’s purpose. I bought mine used and the OP didn’t use any. If I had bought new, I likely wouldn’t have used any either - making the assumption it was overkill for idiots who don’t know how to tighten down a bolt. They should state it’s for corrosion protection and that without it the bolts WILL 100% fuse themselves to the crossbars even after only a short time in the most delicate of conditions.
  17. May 22, 2022 at 9:03 PM
    daveleau
    daveleau Active Member
    2015 gunmetal gray Tacoma SR5
    3" lift, winch
    If you cannot get it out, you can buy individual rails from Prinsu to replace that one rail. Or, you might ask customer support sbout this issue and they may surprise you with a new rail.
  18. May 22, 2022 at 9:18 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    was about to say that or you can even buy them online via a few different places for about $20. https://www.tnutz.com/product/ex-10...tted-aluminum-extrusion-for-prinsu-roof-rack/
    they also supposedly have a lifetime warranty from prinsu/cbi so you would always try hitting them up.
    SR-71A likes this.
  19. Jun 21, 2022 at 11:15 AM
    valdark
    valdark Well-Known Member
    They sent you 6 new crossbars for free?!
  20. Jun 21, 2022 at 12:28 PM
    mysubiewasalemon
    Yes sir and all new hardware, again you have to be the original owner with proof of purchase.
