Sheared screws on my Prinsu Rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Georgeth1022, Nov 2, 2021.
  1. Jul 8, 2025 at 9:59 AM
    #41
    ccjiv94
    ccjiv94 Not Mechanically-Inclined
    Colin
    Hanover, MD
    2021 Tacoma TRD Off-Road 4x4
    Magnuson Supercharger OTT SC MT Tune (Spicy) 3-inch Lift & Leveling Kit Morimoto Headlights & 3rd Brake Light AlphaRex Tail Lights KMC Recon Rims BFG All-Terrain Tires Fab Four Front Bumper Victory 4x4 Rear Bumper w/ Swingarms Fox Front & Rear Suspension Upgrade Baja Designs Auxiliary Lighting (S8, Onx6, & Squadron) Bantam SPod System Prinsu Roof Rack Meso Customs Interior Map/Dome Light
    Just reached out to Prinsu/CBI for this same issue and was told that the warranty doesn’t cover the corroded crossbars and hardware. I was offered a partial refund on one new crossbar but will likely need to buy an entire new rack’s worth of crossbars. Every single crossbar is experiencing seized hardware and corroded crossbars.
  2. Jul 8, 2025 at 7:48 PM
    #42
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    How long ago did you buy it ? Did you have the paperwork from the original purchase. Cbi bought prinsu right when I got my replacements but that was awhile ago
  3. Jul 8, 2025 at 8:45 PM
    #43
    ccjiv94
    Colin
    Hanover, MD
    Yeah, they’ve likely changed how they perceive the issue during that time.
    I had the roof rack installed in 2021 and have the original invoice from the approved installer (and offered to obtain the approved installer’s initial order) and the original Prinsu/CBI staff member I spoke to said that was fine since they updated systems in 2022 and have no prior records. However, a second staff member intervened and said: “Unfortunately, this is not something that we cover under warranty as there are several variables that can affect the hardware, such as climate, torque applied when installing, etc. But, we can offer a 40% discount code on a new crossbar if you are unable to remove the broken bolt.”
    You would assume that since both the crossbar and the Prinsu supplied hardware are significantly corroded, they’d own up to it as a design issue. So I’m probably getting 40% off of one crossbar at a time as I swap them all out. Or getting 40% off of the first crossbar and getting to buy the rest at full price. I’m going to try to be proactive this time and apply never-seize lubricant to all the hardware and crossbars as I swap them all out.
