Sheared water pump
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The scout, Feb 19, 2022.
  1. Feb 21, 2022 at 2:07 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    wonder if there are batch numbers to see if they were produced at same factory during the same period.
    tacoman45 and Taco 422 like this.
  2. Feb 21, 2022 at 2:24 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'm sure it is trackable given the knowledge of the manfacturers tracking systems.
  3. Feb 21, 2022 at 2:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    @Lucario Runner
    Correct. Either similarly poor castings, which would be astronomical to have closeness, due to age of vehicle and new part.
    Which leads to installation related or another part causing an issue.
    Since the s/c belt doesn't use the waterpump pulley for tension, then something weird is really going on. Alignment, fan clutch, etc....
    TnShooter likes this.
  4. Feb 21, 2022 at 3:03 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    That is fucking impressive. First place I'd look at are the weep holes to look for areas of compromise. Second I'd look at the fan and fan clutch, couldve been imbalanced. Lastly I would bring the system back to spec and do a leak down test/pressure test. If two virgin pumps did that and they were Toyota/aisian pumps (at least one was per the pic) it would take a bit of pressure to break one more so than hoses but worth a look.
    Torspd[QUOTED] likes this.
  5. Feb 21, 2022 at 3:49 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Based on almost 40 years in manufacturing, about zero. I'm still leaning towards too much belt tension.
    Jimmyh[QUOTED] likes this.
  6. Feb 21, 2022 at 4:03 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I couldn't see belt tension being an issue with the way the water pump is driven on 4.0l trucks, it sits in the middle of the belt so tension should be about equal on both sides no matter how tight the belt is unless it's routed differently with a S/C.
  7. Feb 21, 2022 at 4:38 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    It's not. This Sc belt is separate.
  8. Feb 21, 2022 at 6:28 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This impressive > :violent:
  9. Feb 22, 2022 at 10:07 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Holy shinto that must've taken a lot of force to break that off. And I'm surprised the belt held up through all of that. I'm no mechanic, so just giving thoughts. Seems like one of the pulleys in that system just creates a ton of belt tension and shear force on that water pump. I'd check all the pulleys and maybe even replace them all to be safe. I'd also check everything the pulleys are mounted to since a lot of force was likely placed on all those pulleys. It's just the water pump was the weakest link. Was there any wear on the inside of the belt? Like it was dragging on a frozen or semi -frozen pulley?
    My other thought is that it could be related to the supercharger install (pulley) since that's the only thing that changed from your truck working to blowing two water pumps in a row.
    Maybe instead of a frozen pulley, there's one that just create a lot of resistance, since it seems to take a month of use before it breaks the water pump.
    Anyway, hope you (OP) figure it out and I'd like to know what happened.
  10. Feb 22, 2022 at 10:19 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don’t know what caused it, but it might not be a bad idea to inspect the timing cover once’s it’s off.
    I’d be looking for stress fractures or cracks. I’m sure someone out there has the knowledge to look at the broken area of the pump under a scope and tell you how long it took to fail.
    Was the pump stressed over time? Or a was it instantaneous failure? (My guess is no)
    But those guys that have that knowledge, probably aren’t here on TacomaWorld worrying about a water pump. :rofl:
    I think there is more to it than belt tension. If that were it, I’d expect to see other rotating assembly fallers on the same belt. Such as the alternator, power steering, idlers, ect…
    Jimmyh likes this.
  11. Feb 22, 2022 at 11:05 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    This is all anecdotal, so take it w/ a grain of salt, but as an engineer but I'd say that looks like a brittle failure, given the sharp edges along the fracture lines and lack of metal tearing or signs of significant yield prior to plastic rupture. The metal itself looks granular, but it's hard to really say without seeing the part up close. I'm assuming it's an aluminum part, so that probably explains some of what I'm seeing here.
    Another thing I see is the shear plane follows a line that makes it look like this might have been a torsional shearing failure. Is there a possibility for something to get locked up between the pump & the fan motor? The idea here is the fan would be blocked from rotation and instead transfer that torque back to the pump housing, causing the shearing you see in the pic. It looks like the pump housing isn't bolted up correctly either, just looking at the bolts in the upper left and the lower right of the picture.
    My gut says it was either a chinesium or counterfit part with poor QA/QC. Maybe OP returned the failed part back to the vendor and vendor unknowingly sent back another counterfit part from the same batch. I'd be interested to see what you guys thing about the torsion transfer from the fan motor though...
    Torspd likes this.
  12. Feb 22, 2022 at 11:23 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    Give that man a beer... :hattip:
    tacoman45 likes this.
  13. Feb 22, 2022 at 11:25 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Ho Lee Krap! :eek: that is most impressive and depressing at the same time. Did the first one land facing the same direction when it failed?
    I don't have the SC, so I don't know the serpentine belt routing, but I'm wondering what would happen if the SC sucked the tensioner to max and wanted more. If that makes sense...
    Do they offer a different tensioner for the SC?
    I dunno.:notsure: just throwing it out there...
    Good luck in figuring it out
  14. Feb 22, 2022 at 8:38 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    What fan motor?
    The fan and water pump is turned by the serpentine belt that is driven by the crankshaft pulley.
    Engine | Water Pump | Fan Clutch | Fan Blades
