Shell Light
Discussion in 'Lighting' started by backwoodking, Oct 24, 2008.
  1. Oct 24, 2008 at 3:17 PM
    backwoodking
    backwoodking [OP] Well-Known Member
    Thousand Oaks/Southern CA
    3.4 V6 Deck Plate and Cut Turn-Down
    Deck Plate, Hitch, Cut Turn-Down Exhaust, Tint, Clear Corners, Shell, Full Size bed in the pickup, Hopefully More Soon
    Hey Guys. I just acquired a shell for my truck and I put it on and it looks pretty good. The only problem is that when Im camping it is always dark. There is a light in there, but I can't figure out how to hook it up. I would like it to be hot all the time because it has a switch on it. Anybody have any good ideas? Thanks
  2. Oct 24, 2008 at 3:30 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Simple answer would be to just run a wire up to the battery, with a fuse close to the battery. Finding a ground closer shouldn't be too difficult.
  3. Oct 24, 2008 at 3:30 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    run wires to it and fuse it right and ground it well...
  4. Oct 24, 2008 at 3:51 PM
    TightShirts
    TightShirts The StormTrooper
    TightShirts
    Phoenix... The Land of Lifted Trucks & Dirty Sluts
    08 Rugged Trail Ed
    Tint, Clear Bra, De-badged, In-Dash DVD, 09 Led Tail Lights, Chris4x4's old OME front shocks, 1.5" Deaver AAL with OME n182s, black billet in white sport grill, BHLM w/4500k HIDs + Fogs, bumper blackout
    why not just buy a ac light and use the outlet in the bed? then you could take it out when you're not camping...
  5. Oct 24, 2008 at 4:57 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    run it to the battery, use 5 amp fuse close to the battery. There is a ground point behind drivers taillight (threaded stud)
  6. Oct 24, 2008 at 8:13 PM
    pidro_el_pirata
    pidro_el_pirata Well-Known Member
    Fail.
    Read his bio, he's a first gen, and we first gens don't have plugs in our beds :p
    Backwoodking, I'd recommed to just run a wire to the battery, toss in a fuse, and ground it to the frame under the bed. That's the easiest, most straightforward, and cheapest way to do it. Just requires a little bit of manuevering and zip-ties.
  7. Oct 24, 2008 at 8:19 PM
    tacoma-king
    tacoma-king Well-Known Member
    sault ste. marie Michigan
    1997 Tacoma
    hitch
    I would agree that running a wire to the battery with a fuse and then grounding to the bed or frame is the easiest to do it
  8. Oct 25, 2008 at 12:40 PM
    TightShirts
    TightShirts
    08 Rugged Trail Ed
    :frusty: yep, i messed that one up! i guess thats what happens when i get too eager to help...
    and agree, that would be the best option. i also saw that some second gen people were adding cig lighter outlets in their beds next to the ac so they could have access to both types of power. if you are running the wires anyways could install one of those so you have a power outlet (not ac) in the bed... might be a nice and handy for some of your camping gear, but idk i don't go camping
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/4838-cheap-free-mods.html#post45453
  9. Oct 25, 2008 at 1:04 PM
    pidro_el_pirata
    That's a good idea, I think I might do that actually. My only worry is draining the battery.. It's been dying quickly on me lately, I did some headlight adjusting last night with the engine off and it almost didnt start, it was a very slow chug-chug-chuuuug!
    Cars should have kick starts :D
  10. Oct 25, 2008 at 1:47 PM
    TightShirts
    TightShirts
    08 Rugged Trail Ed
    success! :bananadance: i may have actually helped someone! that doesn't sound good about the battery... maybe something like this could help:
    http://www.directdepot.net/product_info.php?products_id=1832
