Shellshock's DIY inflator / deflator
Discussion in 'Technical Chat' started by Shellshock, Jun 5, 2019.
  1. Jun 20, 2022 at 12:39 PM
    #521
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Cheers!
    Not having to squat the whole time and being able to chat is a big deal for me. A side at a time is perfect. You don't want the four tire version. It is just a messy octopus and too bulky.
    I was using this kit in the garage also, but then ended up getting more stuff. I bought more of the same fittings and gauge. Been checking the tires more often as it is almost fun. Found at least one leak doing that.
    You're welcome! 0.061in is much more stiff than the 0.041in. At least you can rebuild the tool that you made.
    CygnusX191 likes this.
  2. Jun 20, 2022 at 12:53 PM
    #522
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
  3. Jun 25, 2022 at 4:42 PM
    #523
    Shellshock
    Shellshock [OP] King Shit of Turd Island
    Iowa
    Forgot to post this. I’ve been using a 1/4” version. Nice part is it fits in my ARB compressor case
    Slashaar, CygnusX191, wi_taco and 3 others like this.
  4. Jun 26, 2022 at 4:18 PM
    #524
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    Looks good! Planning on doing this soon. For your latest 1/4" version did you still go with 6ft whips for the shorter runs? I'm not finding those so assuming you instead did a 25ft hose and then just bought the individual pro/swivel fittings.
  5. Jun 26, 2022 at 5:09 PM
    #525
    Shellshock
    Iowa
    Yep I went with a long hose and chopped it. Bought a couple flexzilla pro fittings for the ends and a generic 1/4” T fitting for @tonered clamps in the middle.
    I believe this are 7’ and the lead is 8’. Went a little longer since the hose is thin.
  6. Jun 26, 2022 at 8:35 PM
    #526
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
    Nice! So which is faster, your 3/8" or 1/4" version? :) Also, are you still using the (v2) pressure regulator setup? I'm thinking about going that route, but I'm not exactly sure how it works. Maybe you can enlighten me.
    EXAMPLE: If I install a 90 - 120 pressure switch on the compressor, it will shut off the compressor at 120 psi. If I also add a 50 psi regulator, it will limit the air pressure to 50 psi.
    So, in this scenario, will the compressor ever shut off, or will it continue to run, but at 50 psi? TIA!
  7. Jun 26, 2022 at 9:15 PM
    #527
    Shellshock
    Iowa
    I should compare them. I keep forgetting to do that
    I usually use the flexzilla inflator. The regulator I got came with the wrong gauge and I never got around to replacing it. It works well for inflation but not so much for deflation (it’s super slow)
    if you have a 50 psi regulator, the compressor still still shut off because the pressure behind the regulator will still build, tripping your pressure switch. So you’d have 50 psi forward of the regulator and 120 in the hose behind it
  8. Jul 7, 2022 at 5:07 PM
    #528
    cactushead
    San Diego
    Thanks guys for leading the way on these compressor mods! After making both versions of @Shellshock 's SDI, I decided to make @tonered 's Viair 300P mods. I wanted to refine it, so it would have a cleaner look, without the relay wires or extra hoses. As Tony told me, his looks a little Frankenstein with all of the wires! :rofl:
    This would require moving the relay to the inside of the switch cover. Looking inside the cover, I was able to find enough space for the relay and the panel-mounted XT60 connector. This connector allows me to switch out the pressure switch, or to bypass it altogether by using a bypass plug.
    To do the female quick disconnect mod, I was already changing out the male quick disconnect for a M14 x 1/4" mnpt adapter. This new fitting enabled me to install a Viair multiport Tee fitting above the switch cover and also move the 30A pressure switch (w/attached leads) with it.
  9. Jul 7, 2022 at 5:22 PM
    #529
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good stuff. I like it.
  10. Jul 12, 2022 at 1:30 PM
    #530
    Shellshock
    Iowa
    parts list for v3 added to the second post (what im currently using)
    lot of this stuff is currently on sale for prime day too
  11. Jul 15, 2022 at 7:43 PM
    #531
    T.Barn
    T.Barn Well-Known Member
    Todd
    Hampton Roads, Virginia
    2010 AC 4x4 6MT
    Thank you guys very much for the info in this thread. Ever since I saw the 4-way inflator I wanted one but there was no way I was going to pay the price of one knowing the materials could be worth that much. I was able to make it for a fraction of the cost all from Amazon and from info/parts in this thread.
    I was also able to find a good quality jumper cable bag for cheap on Amazon in order to store the kit in. Took a gamble on the size and it worked out perfectly. Let me know if you want a link to the bag I got. It’s also got another pocket up front to carry miscellaneous items. I am using it to carry extra valve stem caps as I tend to lose them often when airing up/down.
    5299D172-AD8B-4330-804A-928E7D6E3698.jpg 69D78BCF-B8C0-46A4-8BD2-127826E9BF7E.jpg ABD0F902-181D-4B36-B5F6-4BE45599A0EC.jpg 6D2289FA-EF1D-47B6-82DA-C5FD85D51266.jpg D65D0BE0-FB66-4454-9D0C-90152F6DCA84.jpg
  12. Jul 19, 2022 at 9:15 AM
    #532
    WhiskeyHole
    WhiskeyHole Well-Known Member
    Columbus, Oh
    2013 PyriteMica
    Mostly stock
    Nice! Super clean. A parts list would stellar if you have the time?
  13. Jul 20, 2022 at 12:25 AM
    #533
    cactushead
    San Diego
    Thanks! I tested it out for the first time today with the 0-60 psi regulator that @Shellshock found and it worked great.
    These are the parts I used to add the pressure switch:
    1. Any Bosch style, 4 pin relay. I had a box of 6, 5 pin relays, so I used one of those, instead. For a better fit, I removed the part of the relay cover that holds the metal mounting tab. It's a tight fit under the switch cover, so you will also want to minimize the amount of wiring you use.
    2. A Metric Fitting, Male Adapter: M14X1.0 to 1/4" NPT.
    3. A Viair Multiport (Tee) Fitting. I used P/N 92846, but P/N 92821 will work, too. It just depends if you want to connect a 1/4" mnpt or fnpt QC.
    4. I originally wanted to find a high amp pressure switch so I could omit the relay. I thought one of the Viair 30A sealed pressure switch would be suitable, but after conferring with the owner of Newmatics, Inc. (an air ride suspension company), I decided to use a relay and not risk destroying the PS. Coincidentally, Newmatic has their own branded PS that look identical to the Viair sealed pressure switches. These are probably rebranded Viair switches, as the specs are also identical. For instance, the 50223 I purchased and the Viair 90223 are both: 30A, 90/120 psi, with 12 AWG, 5.25" wires. The major difference is about $13 in the price ($19 vs $32).
    5. XT60 panel mounted connectors. There are a lot of vendors selling this types of connector. However, the ones I purchased are made of nylon, not plastic like others on the market.
    6. Most of the sellers do not include screws with the connectors. If you need to purchase screws separately, the thread size is M2.5 x .45. The length I bought was 8mm.
    Let me know if you want a step by step installation write-up.
  14. Jul 20, 2022 at 8:30 AM
    #534
    WhiskeyHole
    Columbus, Oh
    2013 PyriteMica
    Mostly stock
    Awesome. Seems like all good quality stuff.
    Thanks again.
  15. Jul 27, 2022 at 6:14 PM
    #535
    WhiskeyHole
    Columbus, Oh
    2013 PyriteMica
    Mostly stock
    FYI - They don’t fit.
    CygnusX191 and tonered like this.
  16. Jul 27, 2022 at 6:16 PM
    #536
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That stinks.
    I'm sure that you can sell them off pretty easily.
  17. Jul 27, 2022 at 8:34 PM
    #537
    Shellshock
    Iowa
    You could get a set of these
    Muzzys (Pack of Four) Double Seal Flow Through Valve Stem Tire Caps, Inflate Thru for High Pressure Truck Car RV Semi Bus Tires -INFLATE Tires and Check Pressure Without Removing The CAPS!- V2B DS-1 https://www.amazon.com/dp/B08BVVJCFQ
  18. Aug 1, 2022 at 9:15 PM
    #538
    wi_taco
    Adam
    Question for all you fine folks who have built & used one of these kits: I see most people making the leads to each wheel equal lenghts of about 6 feet. Wouldn't it (at least in theory) be better to make them different lengths, i.e. offsetting the compressor lead to one side? Generally most people will have the compressor on either the driver or passenger side and not the center. Doing it this way would allow you to use a couple feet less hose which means a smaller package to carry. It's not a huge deal but hey why not optimize it a little more?
    Example to show my sick MS Paint skills:
    VE7OSR and CygnusX191 like this.
  19. Aug 1, 2022 at 9:24 PM
    #539
    Shellshock
    Iowa
    You could make like a 1ft and a 11ft but that’s not how my brain works and wanted them equal…cuz I’m equalizing
    I figured there’s some physics fluid dynamics thing where it would over inflate the tire with the short hose cuz of less resistance or something then youd have to wait for them to equalize between them
    or maybe that’s not true but that’s how I thought it through and never tried one with unequal lengths.
    someone smarter than me can do the math on that lol or make one to test it and report back
  20. Aug 1, 2022 at 9:50 PM
    #540
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Mine is roughly equal. The ones that I made for other folks are unequal. I base it off of the type of compressor and where the compressor is.
    Zero issue either way.
    CygnusX191 and wi_taco[QUOTED] like this.
