Shellshock's DIY inflator / deflator
Discussion in 'Technical Chat' started by Shellshock, Jun 5, 2019.
  1. Jun 12, 2020 at 4:54 PM
    #81
    Shellshock
    Shellshock [OP] King Shit of Turd Island
    Iowa
    ihatemytruck[QUOTED] likes this.
  2. Jun 12, 2020 at 5:29 PM
    #82
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
  3. Jun 12, 2020 at 6:46 PM
    #83
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Is there 2 different styles? They must be open if they are not dealing when I remove them from the valve stem.
  4. Jun 24, 2020 at 4:03 PM
    #84
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    Word to the wise - check when you are getting "closed" air chucks that they open when attached to the stem, and not open when they see air flow. If you get the ones that only open when there is air flow they won't work for this system.
    babelfishinmyear likes this.
  5. Jul 22, 2020 at 10:52 PM
    #85
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    I finely got some time today to look at the tire inflator and figure out why the chuck was leaking when it was removed from the valve stem. Turns out it was a very simple fix, a drop of WD40 to lubricate the valve and it shut no problem. I think that because I opted to use ¼ inch hose vs. the ⅜" hose, that there isn't enough flow to reseat the nice new valve with tight tolerances, so a little lubricant and the valve shuts perfectly now.
    Crow Horse and Shellshock[OP] like this.
  6. Jul 23, 2020 at 6:13 PM
    #86
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    I've got a smittybilt compressor and I could've sworn it said only use open hose accessories. Is that something I'll need to factor into a build like this or is there no concern?
  7. Jul 23, 2020 at 6:19 PM
    #87
    Shellshock
    Iowa
    The only thing with using closed chucks is you either need a way to bleed the line or be prepared for it to drain when you disconnect the hose after you are done.
  8. Jul 23, 2020 at 7:08 PM
    #88
    CAG Gonzo
    2018 OR DCLB BarRed
    So a closed system won't damage the compressor itself, I just have to be wary that the line is pressurized when I turn the compressor off and start packing it up?
  9. Jul 23, 2020 at 7:16 PM
    #89
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Technically if it isn't closed, then it isn't a compressor system. It's an Air pump. Whenever I am finished with my compressor and hoses, everything get drained. Not reason to leave it charged.
  10. Jul 23, 2020 at 7:16 PM
    #90
    Shellshock
    Iowa
    I don’t see how it could. If the compressor doesn’t have a pressure shut off switch, then you’ll want to make sure the compressor gets shut off and doesn’t just pump up the air line. Outside of that, it’s really no different than an open system.
    Speedfreak likes this.
  11. Jul 23, 2020 at 8:31 PM
    #91
    CAG Gonzo
    2018 OR DCLB BarRed
    It doesn't have a pressure-based switch, just temperature. I checked the manual and online and can't find confirmation from Smittybilt that you shouldn't use closed chucks. But without a pressure switch, it sounds like if I'm not inflating anything then the compressor will just keep at it until something explodes or I turn it off. So...I either need to get a different compressor or find a pressure switch. A cursory google hunt has revealed it's possible but no leads on the specific model yet or how it works.
  12. Jul 23, 2020 at 8:49 PM
    #92
    Shellshock
    Iowa
    Or you just connect all the hoses, turn compressor on, reach desired pressure, turn compressor off. Switch tires. Repeat.
    It’s not really an issue, it’s just you need to be aware of it. There’s lots of compressors out there without pressure switches in them.
    if you don’t want to turn the compressor off, you could also either get another fitting and valve or a gauge that has a bleed function that you can use to open the line
    mac_2_nite and doublethebass like this.
  13. Jul 23, 2020 at 9:58 PM
    #93
    CAG Gonzo
    2018 OR DCLB BarRed
    Thanks for the juicy info!
  14. Jul 27, 2020 at 9:46 PM
    #94
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    Has anyone done a time trial yet?
  15. Jul 27, 2020 at 10:26 PM
    #95
    Shellshock
    Iowa
    I’ve compared with buddies when we start at the same time. I also like being able to stand around instead of touching each tire individually. Plus the equalization side to side is great, especially if you ever look at the readout in the mfd
    mac_2_nite and tonered like this.
  16. Jul 28, 2020 at 11:48 AM
    #96
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    That clamp tool is awesome. I think I need that. Any recommendation for wire gauge for general use?
    tonered[QUOTED] likes this.
  17. Jul 28, 2020 at 11:52 AM
    #97
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's a killer little tool. I like the flush clamps, esp on garden hoses and such.
    I use the cheap baling wire up to the the nice 0.041in SS stuff from HF. It all works great.
    dilbert[QUOTED] likes this.
  18. Jul 28, 2020 at 12:14 PM
    #98
    Shellshock
    Iowa
    I still need to buy that thing. I totally forgot about it
  19. Jul 28, 2020 at 12:19 PM
    #99
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It has paid for itself in enjoyment. I can't even explain why using it is so satisfying.
    I keep meaning to get an Oetiker clamp tool, but it is rare that I need those. Less than a handful of times. So easy though.
  20. Aug 19, 2020 at 3:37 PM
    #100
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Great DIY project - and very useful... The biggest hurdle is airing down in the time spent (mostly airing-up!). This is great!
    :yay:
