Shift Lever Sticks In Park
Discussion in 'New Members' started by bhdpal, Jan 22, 2014.
  1. Jan 22, 2014 at 2:21 PM
    bhdpal
    bhdpal [OP] New Member
    Maryland
    Yakima roof rack, Wesson Grill Guard, Wesson Grill Fog Lights, Truck Bed cubbie hole lights, Custom built truck bed tool box, interior driver's arm rest, Cabela's camo dirt and stain proof seat covers, Cabela's dirt and water catcher floor mats, door and edge guard protectors, side view globe mirror inserts, class C frame mounted tow hitch and hitch ball step extension.
    72 year old Newbee in love with my '07 Tacoma 4x4 access cab automatic 5 speed V-6 towing package. Haul ATV in bed, canoe on roof rack & tow popup camper. Lots of hunting, canoeing and fishing. Lots of backwoods off road to reach best spots. Proud to be a member of this forum with like minded folks.
    Recent problem! The automatic shift lever locked up in PARK after starting & could not move it into reverse or drive. Tried turning engine off & restarting, no go. Finally put a little muscle on the shift lever and it went into reverse and drive.
    Can Anyone tell me what caused this problem? I would like to know ahead of time before I take it to a mechanic.
  2. Jan 23, 2014 at 3:40 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Welcome to TW :wave:
    Man, I have no idea... bumping this thread so others can see.
  3. Jan 23, 2014 at 4:47 AM
    gearcruncher
    Canadain bumper technician
  4. Jan 23, 2014 at 4:57 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Do you park on an incline? If so, apply the parking brake first then put shifter into park. This way the weight of the truck doesn't torque lock the tranny, perhaps.
  5. Jan 23, 2014 at 5:12 AM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    I read somewhere theres a plastic sleeve on the bottom of the lever that jams up the whole deal.. Maybe thats you issue. Ill see if i can find a link.
  6. Jan 23, 2014 at 5:18 AM
    Ghost848
    Tony
    Alberta,Canada
    Or try this copy and pasted from other thread same deal as yourself:
    This morning I went directly to the Stop (brake) fuse, yes listed as Stop. The fuse panel is located inside on drivers side near door. 10A Stop/Brake fuse was blown. Replaced fuse! Tacoma is now resting comfortably back home. Thanks to all for your help. This senile citizen is a happy camper again.
  7. Jan 24, 2014 at 11:31 AM
    bhdpal
    Maryland
    Thanks Folks for all the great suggestions. GearCruncher hit the mark. That one time, I was in a hurry and did not tap the brake pedal before starting the engine. I distinctly remember that I started the engine first and then tried to shift from park to drive and it would not go.
    Also tried the other suggestions and brake lights worked fine.
    I hope this also helps someone else with a similar problem.
    jp
  8. Jan 24, 2014 at 11:37 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Good to hear you got it figured out. Welcome aboard from the High Desert of Central Oregon. GO SEAHAWKS!!!
  9. Mar 14, 2014 at 7:07 PM
    Sky King
    Sky King Well-Known Member
    Sam
    Memphis, Tn
    07 PreRunner SR5
    Serious sound deadening in the cab and extensive audio system.
    I drove to a meeting in a town about 70 miles away. Got out, attended meeting. Got into truck, started, couldn't shift out of park. Had my foot on the brake, restarted engine, all no help. Since it was dark, it was easy to note that my brake lights were not working. Further investigation found that tail lights, license plate light and turn signals all inop. Found three fuses blown for these lights.
    Previous owner had installed an aftermarket trailer light adapter and it had shorted out blowing all these fuses. With no power to the brake light circuit, the shift lockout did not unlock.
    I took the wire cutters, cut the wires to the trailer light module, replaced the fuses, everything worked.
