Shift points?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wooddan, Sep 16, 2012.
  1. Sep 16, 2012 at 1:53 PM
    wooddan
    wooddan [OP] Member
    MASS
    10 tacoma dclb
    Access Vanish Tonneau, Weathertech floor liners, Weathertech Ventshades Rugged Liner bed mat
    I recently bought a tacoma and noticed it doesnt really cruise at the speed limit? If that makes sense?
    It seems when i accelerate to 35 or 65 as soon as i let off the brake it almost downshifts and loses speed quickly. I was wondering if it was something all tacomas did or was i having an issue?
    Its a 2010 dclb with the 4.0 auto
  2. Sep 16, 2012 at 2:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The auto tranny mimics a manual, in that it doesnt "Coast" like autos of the past, or other manufacture auto trannys.
  3. Sep 16, 2012 at 2:29 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    This, its engine braking. The computer also "learns" driving habits. You tap the brake, or brake at all, it thinks you want to slow down. So it tries to help you so to speak. Works great for me, with all the hills around here.
  4. Sep 16, 2012 at 2:43 PM
    wooddan
    wooddan [OP] Member
    MASS
    10 tacoma dclb
    thanks for all the relplys. I had never driven a car that didnt coast on its own. I was actually starting to get used to it and it worked to my advantage in the morning traffic but i just wanted to check it was a normal thing.
  5. Sep 16, 2012 at 2:46 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Most mordern vehicles have adaptive trannys that "learn" the users inputs. It will learn your driving style over time. When to shift, how long to stay in gear, engine brake, etc. etc.
  6. Sep 16, 2012 at 9:29 PM
    brianv3ntura
    brianv3ntura Well-Known Member
    Jacksonville FL
    MGM'12 Taco TRD Sport 4x4 DCLB 4.0L 5spd Auto
    Stock for now.
    and also like modern cars, you use more gas when putting into neutral compared to leaving it in gear when stopping or braking.
    many cars have fuel-cutoff when decelerating until a pre-determined speed. putting it into neutral early will use more just to keep the motor from stalling.
  7. Sep 16, 2012 at 10:27 PM
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
    Good thread, I had the same question. After getting a new muffler the downshift around 35mph became super apparent.
