shift solenoid
Discussion in 'Technical Chat' started by yota243, Aug 10, 2013.
  1. Aug 10, 2013 at 8:28 AM
    yota243
    yota243 [OP] Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Got an 05 4.0 auto. and I have a horrible vibe between 4-5 if I drive in d. if I drove in 4 then shift manually to d it isn't there so everone I've talked to says its my OD SHIft solenoid. I've looked and haven't seen a write up on replacing one and was wondering if anyone could either post a hyperlink to one or tutor me up a bit here thanks.
  2. Aug 11, 2013 at 5:36 AM
    yota243
    E.J.
    north Alabama
  3. Aug 12, 2013 at 7:38 AM
    yota243
    E.J.
    north Alabama
  4. Aug 12, 2013 at 7:52 AM
    medic2230
    Murph
    Bama! Roll Tide
    Wouldn't that be internal in the transmission? Done by valves or something like that?
  5. Aug 12, 2013 at 8:23 AM
    yota243
    E.J.
    north Alabama
    Is the solenoid not just a plunger type valve. I think there supposed to either be open or closed and it seems like its getting stuck in between. when I run thru the gears 2500+done it shifts fine. I assume I make enough pressure to fully open or close said plunger
