Shift Solenoid
Discussion in '1st Gen. Tacomas (1995-2004)' started by RobbD, Jan 16, 2024.
  1. Jan 16, 2024 at 1:53 PM
    RobbD
    RobbD [OP] Member
    Robert
    1998 Tacoma SR5 4x4
    None
    What would keep causing a shift solenoid to keep failing? I have replaced the “A” twice in 3 weeks and tested each and both were bad. They are OEM from Toyota. Am I just having bad luck or should I look elsewhere?
    1998 SR5 2.7L A340E transmission.
  2. Jan 16, 2024 at 7:29 PM
    02hilux
    Planet: EARTH
    OEM as online through ebay/Amazon or walk-in purchased from the local stealership?
  3. Jan 16, 2024 at 10:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Dirty/debris in the fluid is the main cause of shift solenoids failing. Did the replacement unit you got test good before you installed it?
    What is the condition of your fluid? Did you also replace the filter? Was there a lot of crud on the magnets and the bottom of the pan?
  4. Jan 17, 2024 at 2:28 PM
    RobbD
    RobbD [OP] Member
    Robert
    1998 Tacoma SR5 4x4
    None
    Yes it was tested before installing. I change the fluid and filter religiously every 38-40 thousand miles and the pan has been clean.
