Shifter bushing repair aftershocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by Alan01tacoma, Sep 11, 2019.
  1. Sep 11, 2019 at 6:32 AM
    Alan01tacoma
    Alan01tacoma [OP] New Member
    2001 Tacoma 4x4
    replaced shifter bushings
    I'm new to the forum, where I learned the cause of my problem with a wiggly shifter on my 2001 Tacoma 4x4 with 250K miles. I then had the bushings replaced at a repair shop and now the shifter is firm but the entire truck shimmies, even when sitting still. It's also noticeable under power, almost like the engine itself is out of time, though the engine was fine before and wasn't part of the repair. I'm thinking that in tightening the shifter the movement may have been transferred back to the drivetrain itself, but that's just speculation. Anyone experienced this or have ideas about it? The shaking is so pronounced that it seems likely to cause damage elsewhere. I have not yet returned to the repair shop because I'd like to be armed with a little more knowledge beforehand. Thanks!
  2. Sep 11, 2019 at 6:57 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    It sounds like a driveshaft that's been reinstalled wrong... but the problem with that is they shouldn't have removed the transmission to fix the shifter, you can do all that from the top
    Do you know if they took the transmission out of the truck?
  3. Sep 11, 2019 at 9:32 AM
    Alan01tacoma
    2001 Tacoma 4x4
    Thanks for responding. They did not take the transmission out, everything was done from the top. The only other thing they did was change the oil. I called them and they said it was misfiring and that was the source of the shaking. It definitely wasn't doing that before I took it in for the bushing repair, but it does seem to run a bit unevenly, much more so when you put it in gear, and the whole truck starts to shake with speed. I suppose it's possible that it coincidentally developed a misfire while in the shop, but it seemed logical to think it was related to the work done.
  4. Sep 11, 2019 at 10:26 AM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Sounds like the shop is not a good one trying to rip u off imo
    skeezix likes this.
  5. Sep 11, 2019 at 12:27 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I'd check your engine bay. They might of knocked something loose. A connector? Anything I can do on my own this is why I do it. Now you are chasing gremlins that you didn't make. Sucks. Hopefully you figure it out.
  6. Sep 11, 2019 at 1:30 PM
    Alan01tacoma
    2001 Tacoma 4x4
    That's good advice, I appreciate it. I doubt they did anything intentionally but it's possible a spark plug wire got knocked loose.
    Xbeaus likes this.
