shifter bushings?
Discussion in '1st Gen. Tacomas (1995-2004)' started by K9kodi, Jul 22, 2016.
  1. Jul 22, 2016 at 10:01 PM
    K9kodi
    K9kodi [OP] Well-Known Member
    1997 Tacoma x cab 4x4 2.7
    3" body 2.5" spacer
    is there a preferred manufacturer or brand other then factory. I notice a little slop and when i try to twist the shifter i notice a slight give. Im looking for new bushings, any suggestions?
  2. Jul 22, 2016 at 10:10 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Marlin crawler sells the best replacement shifter seat and socket imo.
  3. Jul 22, 2016 at 10:29 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    krustytaco and FirstGen Jer like this.
  4. Jul 23, 2016 at 2:48 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    All mine get replaced with Marlin Crawler all though they won`t fix a worn bearing problem
  5. Jul 23, 2016 at 6:14 AM
    FirstGen Jer
    Jeromey
    What bearing are you mentioning?
  6. Jul 23, 2016 at 9:55 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The ones in the Transmission that allow things to move enough to Jump out of gear.
    One would always go for the cheap easy fix as really worn shifter bushing will allow the shifter to jump out of gear.
    Hence the It won`t fix worn bearings !!
  7. Jul 23, 2016 at 10:24 AM
    K9kodi
    3" body 2.5" spacer
    It doesn't pop out of gear it has the same symptoms of my last Toyota with worn shifter seat and socket. I just wanted to know if there was a better option over dealer replacements
  8. Jul 23, 2016 at 11:36 AM
    FirstGen Jer
    Jeromey
    Thanks. That's what I was wondering. I replaced mine and it took out all the "slop". I asked that because my 1st gear occasionally will slip out of gear. It's also not so smooth going from neutral to first gear but that's the only gears I have issues with.
  9. Jul 23, 2016 at 2:08 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I replaced my good condition OEM shifter bushing/seat with the Marlin Crawler ones and it made a noticeable difference
