Shifter Cable
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SouthernTierTaco, May 4, 2023.
  1. May 4, 2023 at 7:44 AM
    SouthernTierTaco
    SouthernTierTaco [OP] New Member
    2005 Tacoma
    I have a 2005 Tacoma, 4Lv6 Access Cab,4x4 with auto trans. Shifter cable is stretched and is hard getting into gear if I can get it in gear at all. Called numerous dealers and all have told me they don't have the part (33820-04010) or do they have an "ETA" on when they will become available. Even had one parts manager tell me that the part is not available at all in the USA. Called Toyota Customer Service and got nowhere. Even checked local salvage yards and found nothing. I do not drive the truck, don't want to damage the trans, but I do start it everyday. Oh yea, the truck only has 65,000 miles on it. Any suggestions would be appreciated. Thanks.
  2. May 4, 2023 at 8:02 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Define "Hard to get in gear"
    I highly doubt that the cable is stretched as it is never under a strain with normal usage.
    Here is what I suggest:
    Disconnect the cable from the transmission linkage and then shift it through the gears. I'll bet there is no resistance at all.
    The problem more than likely is the Park Neutral Safety Switch on the opposite side of the transmission. They are known to have issues with age. I'll locate a picture and post it here.
    Note: With age the corrosion can make these a bear to remove. Purchase some PB Blaster or some other penetrant and soak it for several days. Do not beat on the shaft as it could damage the transmission.
    SR-71A and Dm93 like this.
  3. May 4, 2023 at 8:42 AM
    SouthernTierTaco
    2005 Tacoma
    "Hard to get into gear" is using much force to move the shift lever. I will give your suggestion a try for sure. Thank you for the input.
  4. May 4, 2023 at 10:10 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    That sounds like the Park Neutral Safety Switch, I'm as sure as I can be without seeing it in person.
  5. May 8, 2023 at 1:22 PM
    SouthernTierTaco
    2005 Tacoma
    Went to take linkage apart and that looked pretty rusty so I sprayed that and the NSS with PB ... both several times a day a for the past few days. Just for giggles I tried to move the shifter before I went at the linkage and it worked. Easy to move and it moves the entire range (it took some effort just to get the thing from Park to Drive and wouldn't go into the lower gears). Took it for a drive, shifted properly and ran just fine. Gonna' order a new NSS anyway, better safe than sorry. Thanks Jimmyh.
    Jimmyh likes this.
