Shifter gets hot
Discussion in '1st Gen. Tacomas (1995-2004)' started by 97TacoNM, Dec 1, 2014.
  1. Dec 1, 2014 at 12:40 PM
    97TacoNM
    97TacoNM [OP] Riding a 97 Taco
    Jim
    NM
    97 Taco LX 4x4 Ext Cab
    Rampage halogens Custom bed rack
    I've noticed, on occasion, my shifter gets quite warm. The 4WD stick as well. Being a 97 I don't see that the computer is tossing tranny temp at my Scan Gauge II, so no idea what that temp is when this occurs. Engine temp is normal when this happens. Normal, or something to be looked into? 2.7L 4wd, manual hubs (if that matters). Not doing any 4x when this happens, no codes being thrown.
  2. Dec 1, 2014 at 12:43 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    it has to be tranny heat doing it, check levels/change fluids
  3. Dec 1, 2014 at 12:51 PM
    97TacoNM
    Jim
    NM
    Only way to check the level in this is to open up the fill plug,eh? I cannot find a dipstick on this one.
  4. Dec 1, 2014 at 12:59 PM
    keakar
    karl
    louisiana
    oh 4wd, lol ok well yep that's it check the fluid level but if you have heat issues just change it no matter the level. then see what it looks like. probably got enough miles on it to need a change anyway.
    another thing that might be putting out a lot of heat would be a restricted cat
  5. Dec 1, 2014 at 1:20 PM
    97TacoNM
    Jim
    NM
    Considering its 17 years old and only 130k on it, not bad, but I suppose it can use a change. I'm hoping the cat is ok, would rather not have to deal with that right now, but could change that out as well if needed. I'm not noticing abnormal heat in the passenger floor where the cat runs so have not zeroed in on that so far.
    It's odd. Was toasty driving it out of this parking lot just now. Shut it off for a bit and checked this site on my iPad, fired it back up and the stick cooled down. Like I mentioned it is very sporadic and does just that - hot for a bit then cool.
    Thanks
  6. Dec 1, 2014 at 2:48 PM
    97TacoNM
    Jim
    NM
    I'm heading home to replace the trans oil. Going to use Valvoline Max Life full synth (Dex/Merc, Mercon LV). Anyone know of this being a bad idea before I commit?
  7. Dec 1, 2014 at 3:12 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Mine used to get pretty hot and I attributed it to the rubber cap plug boot thing letting heat up through the transmission hump. I cut another thick rubber cap and screwed it on top of the stock one and it helped a lot.
  8. Dec 1, 2014 at 3:35 PM
    keakar
    karl
    louisiana
    Valvoline Max Life full synthetic is just for auto trannies
    axles and gear boxes get gear oil like this: http://www.mobiloil.com/USA-English...bil_1_Fully_Synthetic_Gear_Lube_75W-90LS.aspx
    that's just an example so just check to see the grade we need for our trucks and what brands others recommend
  9. Dec 1, 2014 at 3:43 PM
    GoldyLocks
    GoldyLocks Well-Known Member
    Mesa az
    97 caged 4x4 tacoma, SR1 Rhino
    LOL
  10. Dec 1, 2014 at 3:44 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    ^^^ that's the stuff I run.
  11. Dec 1, 2014 at 3:53 PM
    97TacoNM
    Jim
    NM
    The ATF brands come up in the search engine at AutoZone for my truck. A quick research I did before buying said some manuals can use ATF, some can't.
    :notsure:
  12. Dec 1, 2014 at 3:56 PM
    97TacoNM
    Jim
    NM
    I'll hold off on the ATF, my Camry can use it for sure and is in need of an ATF fluid change anyway. The AZ guy may have punched in something wrong...?
  13. Dec 1, 2014 at 4:03 PM
    keakar
    karl
    louisiana
    to do a full tranny flush you drain the pan then over fill the pan by adding 4 quarts of new tranny fluid, then disconnect the cooler line hose on the passenger side under the radiator then start the engine for 30 seconds and shutit off, then refill the pan with 2 more quarts and repeat.
    when the engine runs, it pumps out the tranny fluid from inside the tranny internals and replaces it with fresh new fluid just as you would flush the brake lines. its not under high pressure so it comes out slow like a slow running faucet so you start the engine for 30 seconds then shut it off and add 2 more quarts, you refill run and repeat until nothing but clean fresh new fluid comes out then reconnect the hose and top off the fluid level. its really easy and its not very messy as long as you add a short hose to direct fluid into a catch pan if needed. if you end up with too much fluid just unhook hose and pump out the excess fluid then add to your mark.
  14. Dec 1, 2014 at 5:53 PM
    97TacoNM
    Jim
    NM
    Jesus, this seems to be insanely complicated. I went and bought Mobil 1 75w-90, but am now reading on other sites to NOT use this in my '97, as it is designed for hypoid differentials. I keep hearing to use some kind of GL4 fluid, whereas everything AutoZone carried is GL5. AZ only carries a few 75W-90 gear oils, all of which indicate GL5. Castrol, Royal Purple (at $21 a quart), Lucas (more expensive than the Mobil 1). I seem to recall all of them stated they are for limited slip differentials/hypoid differentials.
    Alldatadiy indicates the proper fluid is 75W-90 GL5, so that helps. But what about all this hypoid business?
  15. Dec 1, 2014 at 6:14 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    OP has a manual. All the info you have posted thus far has been for an auto.
    OP, any 75w-90 gear oil should work. With our without LSD additive shouldn't make a difference. I have read that you should use GL4, as opposed to GL5 due to an additive that could effect brass components in the transmission, but don't know much about this. I switched recently from a cheap one to Redline MT-90, which is one of the most recommended oils for our trans. Made a little difference, but not much.
    As far as the change goes, it's just like a diff. Two plugs (both use 24mm socket) take off the top plug, then the bottom, let it drain, and fill it back up. Takes somewhere between 2-3 quarts IIRC.
  16. Dec 1, 2014 at 6:30 PM
    97TacoNM
    Jim
    NM
    Thanks, I have read similar things about GL4 vs 5 as well, but it is all over the map. Interesting that my owner's manual says NOTHING about transmission/gear oil (net even listed in the appendix). Not a word, so I can't find what it is recommending. Alldatadiy supposedly has the same FSM material, and it states GL5.
    Looking through a '96 FSM I have, it states use either GL4 or 5 for the W59 tranny. And all state 2.6 quarts if you drain/fill.
    I think I will call the stealer tomorrow and ask them what they recommend, GL4 or 5 for this. MT-90 is rated as GL4, so I could go that route, but Mobil 1 is less expensive and supposedly the AHHHHHHHH of oils, so ??? It is GL5.
  17. Dec 1, 2014 at 6:40 PM
    Squeaky Penguin
    Brett
    Straight from my owners manual:
    I ran GL5 for over a year with no issues. :notsure:
  18. Dec 1, 2014 at 7:07 PM
    97TacoNM
    Jim
    NM
    ^^ OK, sweet, thanks. Feeling a bit better. I did find the oil specs finally in my owners manual. For tranny and transfer it states "Multipurpose gear oil API GL-4 or GL-5". For the differential it states "Hypoid gear oil API GL-5". From what I read about hypoid it does just seem to be an extra pressure capable oil.
    Others have stated MT-90 as being a great oil to use. It is almost $17/qt from Amazon, quite a bit more than the Mobil 1. I shall ponder this tonight...
  19. Dec 2, 2014 at 8:41 PM
    97TacoNM
    Jim
    NM
    So as I just posted in the what have you done....thread, just put in Mobil 1 synth 75W-90 into both the t-case and the tranny. Each was about half a quart low. T-case only takes 1 qt so that was low. Nothing alarming I think about what came out. Tranny oil was definitely dark brown/blackish. I have no idea when it was changed last. We''l see if I note any more warm shifter issues.
  20. Dec 3, 2014 at 10:33 AM
    keakar
    karl
    louisiana
    if you had even bothered to look at the quote that this post was replying to you would have noticed this was not speaking about his truck but for his CAMRY tranny which is an auto.
