Shifter keeps coming out of 6 spd trans
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hudhawk, May 5, 2011.
  1. May 5, 2011 at 7:23 AM
    hudhawk
    hudhawk [OP] #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    The retaining ring that holds the shifter into the transmission keeps coming loose. Its supposed to go down and twist to lock into place. Its gotten to the point where I'm having to fix it once a week. Please help as it is extremely frustrating when I am driving down the road and it comes loose, then I have to stop somewhere and take apart my center console to fix it.
  2. May 5, 2011 at 7:32 AM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    glue?
  3. May 5, 2011 at 7:36 AM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Yeah, i thought about gluing or just JB Welding it on but then I cant remove it when i need to grease it or if i have to replace to bushing. Have you ever had this problem with your truck?
  4. May 5, 2011 at 7:43 AM
    808matt
    hawaii
    19 Ranger
    you can try some weaker glue that will come loose with force. no need super strong kine. and no i never have that problem
  5. Sep 5, 2011 at 9:03 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    I got a brand new shifter hoping that would fix it but it didnt, so i used some high temp gasket maker around the collar and retaining ring and its all better:D
  6. Dec 15, 2011 at 6:14 PM
    youngblood1856
    youngblood1856 Well-Known Member
    Sterling
    Tyler, tx
    05 Trd off road 4x4 6 speed
    URD air intake, 3" lift, 16" Micky Thompsons classic w/ simulated bead locks, 33" Toyo MT's, exhaust, ATO skids, and okoles.
    my shifter just did this. what do you have to do to fix it?
  7. Dec 15, 2011 at 7:05 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
  8. Dec 15, 2011 at 7:20 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  9. Dec 15, 2011 at 9:00 PM
    youngblood1856
    Sterling
    Tyler, tx
    thanks mine just did this. How do I get to it?
  10. Dec 15, 2011 at 9:14 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Remove the shift knob, the pleather boot, then there will be two screws and two plastic clips holding the rubber boot down, remove those and lift the rubber boot off, then you will see where the shift lever goes into the tranny. You have to push down and twist the top metal retaining ring to get to where the new bushing goes. Remove the shitty stock rubber seat and replace it with the new heavy duty one. Then put everything back together in reverse order.
  11. Dec 15, 2011 at 9:18 PM
    youngblood1856
    Sterling
    Tyler, tx
    Thanks i'm about to order it. It shouldnt hurt it to drive until i get it should it?
  12. Dec 15, 2011 at 9:28 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    No, it won't hurt it, I drove mine like that for months before I finally found the bushing to fix it. You just have to be careful your shifter doesn't come out when your flying down the highway like mine did. Let me know if you have anymore questions.
