Shifter locked in park
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tridge400, Feb 4, 2012.
  1. Feb 4, 2012 at 4:27 PM
    tridge400
    tridge400 [OP] Member
    Maryland
    05 4x4 SR5
    After depressing the brake pedal several times, the shifter will not engage out of park. Anybody had this problem on 05 Tacoma, 4x4
  2. Feb 4, 2012 at 4:41 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    start it up and try it
  3. Feb 4, 2012 at 4:43 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    96 FZJ80
    Slee, ARB, TJM
    Look in the manual. There is a page in there that talks about that litte tab next to the shifter. Use a screwdriver to pry it up(I think), and you can get it out of park.
  4. Feb 4, 2012 at 4:45 PM
    Robert Smith
    Robert Smith Well-Known Member
    take the top of the little square piece on top of the plate that the sfifter goes through. insert a screwdriver and turn this will release the shifter
  5. Feb 4, 2012 at 7:40 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Check your brake light fuse. If it's blown, it won't shift out of park. Also, any aftermarket wiring? Campershell brake light? Trailer harness? If the fuse is blown check the aftermarket add ons first.
  6. Feb 4, 2012 at 7:46 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    X2
    Fuse blew on me a month ago WHILE in a parking lot.
    AS others have said, pop off the little plastic square to the left of the shifter and press the button while shifting.
  7. Feb 4, 2012 at 7:57 PM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    07 4dr 4x4 V6
    Fog Light Mod
    time for a new truck imo or you might wind up like this: :turtleride:
    good luck
  8. Feb 4, 2012 at 9:21 PM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Check IG1 Fuse under dash.
