Shifter moves and i hate it !! why ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by henry310, Feb 26, 2010.
  1. Feb 26, 2010 at 6:34 PM
    henry310
    henry310 [OP] New Member
    Henry
    Huntington Beach, Ca.
    PreRunner
    My shifter moves when i stop and go and i cant figure out why.As I come to a stop I can even feel the thump from underneath. I replaced my
    transmission mount and i really dont think its my motor mounts but just to rule it out I'm probably gonna change those next. Does anyone have any ideas? :confused: 1st Gen 2004 3.4 PreRunner double cab
  2. Feb 26, 2010 at 6:37 PM
    kg4ghn
    kg4ghn Well-Known Member
    GA
    13 PreRunner TRD Sport
    All the first gen autos do it.
    Mine doesn't bother me, but it did freak me out a little the first couple of times I saw it happen.
  3. Feb 26, 2010 at 6:46 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Mine does it as well... I thaught something was wrong the first time I saw it. But I geuss its pretty normal for our trucks.
  4. Feb 26, 2010 at 6:52 PM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
    Shifter movement is pretty normal. The thump is axle wrap and as well is quite common. Nothing to worry about.
  5. Feb 26, 2010 at 7:53 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    The shifter moves, simply because the tranny is moving up and down when you come to a stop, and take off. Remember, the 01-04's were still built like a truck should be, and don't have all the "truck" taken out of 'em like the new ones do.
    If you want to eliminate the movement all together, fab up a front mount for the motor, and eliminate the tripod effect the current setup has.
  6. Feb 26, 2010 at 8:52 PM
    mjhenks
    mjhenks Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
    My 04 does it too. I lubed the drive shaft coupler and it settled down some.
  7. Feb 26, 2010 at 10:56 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    the official explanation i remember being given back in 2002 was that it is a "floating transmission"
    allowing the movement of the tranny keeps the gears from resistance due to torque, yada yada yada...
    i remember back in 2002 on the other forums that folks were returning their tacomas to the dealership and raising hell about it, demanding that Toyota fix the broken tranny mounts...
    9 years and 222,000 miles later, all is well with my dcab...
  8. Feb 26, 2010 at 11:03 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Soo im guessing its normal..
  9. Feb 26, 2010 at 11:04 PM
    JohnnyGato
    JohnnyGato God of Thunder ...and Rock N' Roll!
    Vegas Island
    04 TRD SR5 V6 4x4 Off Road
    Limo tint, Sirius/XM radio, Wet Okole's, Weathertech's, Rhino Lining, blacked out badges, shorty antenna, painted speaker (tweeter) covers, blue LED running lights, Icon 3" lift, Pro Comp 17" 7005's, 33" (285/70/17) Good Year MT/R's with kevlar.
    I noticed that too, but always thought it was a characteristic of the truck. I guess I was right. I have no issues with it.
  10. May 6, 2010 at 12:39 PM
    fish
    fish fish
    winter garden,fl
    04 tacoma 4x4 4 door
    4'' procomp suspenchin lift 33x12.50x17 procomp x terrans and procomp wheels
    my 04 does it too is there anyway to get the bumping at a stop and go to go away?
  11. May 6, 2010 at 10:33 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    04 Prerunner TRD Offroad
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    Mine only moves a little and I actually kind of like it because at least I know I'm driving a truck.
  12. May 6, 2010 at 10:36 PM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    get a 5 speed-problem solved
  13. May 6, 2010 at 10:40 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    2nd gen--problem solved. :p
  14. May 6, 2010 at 10:43 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    6 speed 2nd gen-pwned
  15. May 7, 2010 at 12:22 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Idk if this had to do anything with the shifter or just because I've never notice much movement with it. I greased all the driveline zerk until i saw grease come of the joints, well I've also notice it kinda tighten up the shifter a bit well not tighten but it doesn't jerk as much coming to a stop from axle wrap.
  16. May 7, 2010 at 6:21 AM
    ywen
    ywen Well-Known Member
    it's caused by axel wrap.. do the u bolt mod to get rid of the wrap and the shifter movement.
  17. May 7, 2010 at 6:32 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    My shifter moves as well...but also the indicator mark doesn't line up...if its in drive...the mark points at neutral :confused:
  18. May 7, 2010 at 7:17 AM
    fish
    fish fish
    winter garden,fl
    were do you get the u bolt mod from?
  19. May 7, 2010 at 7:31 AM
    ywen
  20. May 7, 2010 at 4:32 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    i dunno about "solved"
    :threadjacked:
    :devil::devil::devil:
