Shifter stuck in park
Discussion in '2nd Gen. Tacomas (2005-2015)' started by the dude man, Dec 30, 2013.
  1. Dec 30, 2013 at 8:23 AM
    the dude man
    the dude man [OP] Member
    Hi,
    My shifter is stuck in park and won't shift unless I use the override switch. Also the ABS light and traction control light come on when the shifter is stuck.
    It is an intermittent issue sometimes it will go away for a few days only to return for a few days. It isn't the a fuse, and my brake lights are working - so I'm guessing its a sensor?
    Anybody else had a similar issue? How did you fix it?
    Thanks
  2. Dec 30, 2013 at 10:02 AM
    the dude man
    bump....crap
  3. Dec 30, 2013 at 10:04 AM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Next to the shifter is a little black 1/2" by 1/2" plastic cap. Take that off and press the button in there. Then try to move the shifter, it should work.
  4. Dec 30, 2013 at 10:11 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I think (not sure what toyota does) most manufacturers use the brake switch to trigger the solenoid to allow the shifter to be moved.
  5. Dec 30, 2013 at 10:15 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    X2.
    Hopefully the stuck shifter doesn't mean that your brake lights aren't working either.
  6. Dec 30, 2013 at 10:24 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Do urself a favor.....
    Order a new brake lamp switch
    I had same symptoms and after having multiple people including techs and service writers that "the switch will work or it won't, it won't be intermittent".... I finally said "bullshit" and replaced mine.
    Been almost 2yrs.... Guess what?
    No issues...... Not a single one since I swapped it!
    Takes 5 seconds.
    Also worthy note..... I found dielectric grease on the contacts of the old one.... And not uniformly either... Like it was a goof up or something.
    New one had no grease and I left it that way.
    Oh.... Its a dealer only part... So dont even bother calling Napa or anyone else... Just get it from the dealership.
    Califor2A likes this.
  7. Dec 30, 2013 at 10:30 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    For shits and grins, try pumping ur brakes while someone else watches the lights behind you...
    Pump them a few dozen times.... The other person should be able to hear the brake pedal being depressed and be able to say whether ur lights come on EVERYTIME or not... Mine were intermittent.
    This means, just cuz it may get into drive without the bypass, u may not always have brake lights.
    I did wonder if this signal interruption would cause an issue with the cruise control but never tried it... If the cruise looks for a brake signal to disengage passively, would the switch not working sometimes not send signal to the cc?
    U always have the manual off switch.......
    But if someone panicked and just applied the brakes harder in a freak out situation, would the truck try to maintain the set speed because all it sees it resistance and may think its just a grade and not u braking?
    Hypothetical..... But Thats how my brain works.
  8. Dec 30, 2013 at 10:34 AM
    BamaToy1997
    Bill
    Navarre, FL
    Good ideas so far for you to look at OP. When asking for help it would make it easier if you would provide information on your truck like year and engine/trans types. While the Tacoma is still a Tacoma, different models have different wiring schematics and such.
  9. Dec 30, 2013 at 10:37 AM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    Was it this problem that people had when they would wash their trucks ? or was it the ebrake sticking after a wash?
  10. Dec 30, 2013 at 10:39 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Not sure if it helps ya out... His profile thingy says 2009 dblcab auto.
    Sometimes I can't see much info when on my phone.
    I totally agree tho... The more info filled out the better.
  11. Dec 30, 2013 at 10:50 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    There are aftermarket brake light switches now. BECK/ARNLEY Part # 2012337 and AIRTEX / WELLS Part # 1S9836 are listed on RockAuto. However, given the low price of the parts ($17-$25) relative to shipping charges, I still recommend buying from your local dealer if they have it in stock.
  12. Dec 30, 2013 at 11:18 AM
    the dude man
    2009 V6 DCSB
    Thanks for the input - I'll check the brakelights more thoroughly tonight. But I'm going to have to take it to the mechanic. Its too cold outside.
  13. Dec 30, 2013 at 11:24 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    This. I had three go out on two different Chevy Aveos me and the wife had before we got the Toyotas. They are super easy to replace. The switch would give out since it is constantly being pressed in and out. It was located under the break pedal itself. We were able to get the switch off of ebay for $10 shipped. Mine got so bad where the lights would stay on or off. Not just going in and out. My cruise control was also ran through that switch on mine so I would always know when it went out. Replaced two in mine. The wifes was two years older and hers was only replaced once.
  14. Dec 30, 2013 at 11:27 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Mechanic for the install?
    U dont need a single tool... Its a twist and pull item iirc.
    Tacojoe450 likes this.
  15. Dec 30, 2013 at 12:27 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    really bounce on the brake..and then hold it.
    did it work? i had to change out the one in my MIL's car. it was awful! total yoga move under the dash..i hate disconnecting electrical connectors that are designed to really hold. doing it all one handed in tight spaces..awful.
  16. Dec 30, 2013 at 12:36 PM
    tacoma4
    tacoma4 Well-Known Member
  17. Dec 30, 2013 at 1:12 PM
    the dude man
    OK thats awsome! I'll check it out tonite
  18. Dec 30, 2013 at 1:13 PM
    the dude man
  19. Dec 30, 2013 at 5:58 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  20. Dec 30, 2013 at 6:25 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I'm agreeing with Justus on the brake pedal switch. It will also trigger the ABS fault, since the ECU does not see the expected signal from the brake switch.
