Shifter won't budge into any gears...
Discussion in '1st Gen. Tacomas (1995-2004)' started by ericp95, Mar 27, 2020.
  1. Apr 6, 2020 at 3:03 PM
    #61
    ericp95
    ericp95 [OP] Mean Jeanine
    Eric
    04 Tacoma V6 4x4 Manual
    Arrow is pointing to the the shift bushing (it’s like a faint blue, not easily visible in the photo). This is the part we replaced just for kicks even though it was in good condition. Also changed that plastic cover that goes on the ball of the shifter (blurry part of the photo, middle right)
  2. Apr 7, 2020 at 5:49 AM
    #62
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If a shift fork roll pin is is broken and the shift rail is in an engaged position it is interlocked to the other rails. There is a series of small balls and interlock pins that keep the other rails from moving if one of them is selected. So if the roll pin is broken and the rail is selected you have a situation that effectively locks up the entire shifting arrangement. Theres is no possible way to fix it externally the trans has to come out and be dismantled. The good part your parts count will be low. None of the pictures show it but on the steel carrier part there are 3 bolts, behind them are springs and interlock balls.
    MountainPassing likes this.
  3. Apr 7, 2020 at 12:58 PM
    #63
    ericp95
    Eric
    Are you talking about the ones you can access from the side of the transmission? @mechanicjon and I were talking about it earlier in messages
  4. Apr 7, 2020 at 1:01 PM
    #64
    ericp95
    Eric
    He also sent a quick diagram. The difficulty is actually seeing them, you’d have to use a mirror because there are other parts in the way. And getting any kind of tool in there without lowering the trans seems near impossible but maybe someone has done it
  5. Apr 7, 2020 at 1:59 PM
    #65
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    It’s cheaper to just find a used trans and put it in I think.
  6. Apr 7, 2020 at 4:05 PM
    #66
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes but without getting the rods out it will do you no good to remove the plugs. Here is the deal you have got to be able to move the rods and replace the roll pin it is possible to fix the problem with nothing other than moving the rod and replacing the pin but this is transmission on the bench fix. Yes you can move the rods but it does not fix the broken pin and it will happen all over again.
  7. Apr 7, 2020 at 4:10 PM
    #67
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    That is mostly correct they are the detents but in between the rods is a double "ball" it has rounded ends both ends with no spring.
  8. Apr 7, 2020 at 7:34 PM
    #68
    ericp95
    Eric
    gotcha, yea I’m looking to get the trans pulled soon
  9. Apr 7, 2020 at 10:29 PM
    #69
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    My great artist drawing was depicting what he might see if he pulled the plugs and a shift rod was stuck in between. Due to a shifter tha is jump out of the shift gate. Or bronken pin at the fork. Either way the trans needs to come out and be tore down.
    Just was trying to help confirm the problem.
    ericp95[OP] likes this.
  10. Apr 7, 2020 at 11:59 PM
    #70
    ericp95
    Eric
    :thumbsup: Your drawing was great, thank you @mechanicjon
    mechanicjon[QUOTED] likes this.
  11. Apr 8, 2020 at 6:38 PM
    #71
    ericp95
    Eric
    Has anybody bought a rebuilt transmission from Marlin Crawler? They’re saying they do a great job and can stand up to the abuse of rock crawling and Baja racing. Just weighing my options.
    Or I can buy a less than 100k used functioning trans or have mine rebuilt locally which seems like the best option since the shop can do a free inspection of the one I have currently.. which if the damage seems real rough, I can get a rebuilt one from Marlin.
    https://www.marlincrawler.com/transmission/rebuilt-complete/r150f
    frenchee likes this.
  12. Apr 9, 2020 at 9:54 AM
    #72
    toyrunner
    toyrunner Puddle Jumper
    Danny
    Pasadena, Ca.
    2004 4X4 Tacoma TRD Xtra Cab
    Kings in front, Bilstien Reservoir rears, Custom sway bar disconnects, 265/75 16 BFG AT's, ARB front bumper and FROR rear bumper. Bao-Feng 2 meter radio and Cobra CB
    Marlin does exceptional work on the rebuilds. When I was into the mini trucks, those were all I ran. Never any issues.
    Good luck with the fix, however you do it.
  13. Apr 10, 2020 at 7:17 PM
    #73
    ericp95
    Eric
    Picked up a used trans minus the bell housing and clutch plate (I'll just pull housing from mine and probably pick up a new clutch plate). 80k miles on it.... not bad, got real blessed.
  14. Apr 10, 2020 at 8:26 PM
    #74
    Hooligans
    Hooligans Well-Known Member
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Still thinking about it.
    Good job Eric.
  15. Apr 11, 2020 at 6:13 PM
    #75
    ericp95
    Eric
    Thank you sir.
  16. Apr 11, 2020 at 9:55 PM
    #76
    Hooligans
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    You got it buddy. Seems you have had an unusual experience and are handling it well.
  17. Apr 13, 2020 at 4:18 PM
    #77
    ericp95
    Eric
    Talk about unusual, geez luiz. Anybody have this happen before? Bolt broke from its location as my AAA guy was pulling up the truck onto his flatbed.
    Oof!!
  18. Apr 13, 2020 at 10:59 PM
    #78
    mechanicjon
    Jon
    Scottsdale Arizona
    They've been known to get fatigued and break. Especially if they have worked loose. Big tires is another thing.
  19. Apr 14, 2020 at 1:04 PM
    #79
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Also looks like the lower bushing on your shock is pretty blown out
  20. Apr 14, 2020 at 1:12 PM
    #80
    Wulf
    Wulf no brain just damage
    rock raisin
    @BartMaster1234 knows about this
