shifting from first to second
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gmcaree, Feb 22, 2010.
  1. Feb 22, 2010 at 10:46 AM
    gmcaree
    gmcaree [OP] New Member
    hi
    bought a new 2010 tacoma access cab. Having a problem shifting from 1 to 2
    there is a grinding sound. Brought back to dealer and was told it was mats ?
    changed mats and still grinding. Only way i found to stop grinding is going extremely slow from 1 to2. going from 3 to 2 no problem. is there something that needs to be adjusted ?
    thank you
  2. Feb 22, 2010 at 10:49 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Welcome aboard....perhaps the synchro? Or clutch adjustment? Mats getting in the way of clutch pedal depression? Wow! Did they give you mats? They refused me when I asked for them because of the infamous recall.
    Someone far more technically competent than I will surely jump in here and give you sound advice.
  3. Feb 22, 2010 at 10:52 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    definantly take it back to the dealer and tell them to fix it. get on their asses. a brand new truck should not have anything like that going on. and I dont see how mats would cause that. seems to be toyotas scapegoat these days
