Shifting gears without clutch
Discussion in '1st Gen. Tacomas (1995-2004)' started by hc243102, Oct 27, 2014.
  1. Oct 27, 2014 at 6:27 PM
    hc243102
    hc243102 [OP] Active Member
    ohio
    97 tacoma
    97 reg cab 5spd 199000k. I bought it with 150K. Awhile back I had the clutch hydraulics go out on me on a short trip. Wouldn't go into gear unless I pumped the clutch. Got it home, couldn't find a leak but noticed my MC reservoir was low so I replaced the MC and slave with OEM (Aisin) parts. It now operates as it did before, however it is extremely easy to pull the truck out've gear (even under a load) and while the truck is off you can row through all gears without the use of the clutch. This was not the case before. If anybody has any suggestions I would greatly appreciate it, if not I guess l'll just live with it.
  2. Oct 27, 2014 at 6:32 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Sadly, it sounds like the tranny mechanism is just worn out. She's got a lot of miles on her and the springs which hold it in gear and give you the tight feel need to be replaced.
  3. Oct 27, 2014 at 7:15 PM
    leeroycoverdell
    leeroycoverdell Active Member
    Leeroy
    Abilene, TX
    2003 tacoma step side TRD offroad
    Rock defense rear bumper
    All though the springs could be contributing it should not be able to row through the gears the the clutch engaged because the gears usually don't line up like that. I would make sure the clutch is fully engaging because the new parts could not be adjusted properly. Drive the truck around the block and see if you can row through the gears without the clutch again, also try to get the clutch to slip so you can rule that out for sure. Just my thoughts on the issue
  4. Oct 28, 2014 at 5:48 AM
    gearcruncher
    Canadain bumper technician
    As mentioned above , make sure your clutch is adjusted properly .
    Here is a complete repair manual for your truck that I suggest downloading before it disappears .The manual shows how to adjust the clutch .
    http://web.archive.org/web/20101127014333/http://ncttora.com/fsm/1996/96_repair_searchable.pdf
    When the truck is shut off , nothing inside the transmission is turning making it very easy for the synchronizers to select all the gear ranges . This is normal .
    Shifting under load without the clutch can destroy a synchromesh transmission rather quickly . I dont beleive I have ever heard of someone trying to shift a manual transmission while continuing to accelerate . Now if you mean shifting without the clutch while your foot is off the accelerator, it has been done in the past but not a good idea with the style of synchronizer you have in this transmission .
    Here is an example of what can happen when shifting without the clutch $$$$$$$
    Should you shift without the clutch ? http://www.tacomaworld.com/forum/2nd...ion-issue.html
  5. Oct 28, 2014 at 6:25 PM
    hc243102
    ohio
    97 tacoma
    I used that manual to adjust my clutch pedal after I installed the new master/slave. 7inches from the floor, .5 free play.
    Perhaps the title to this thread is a little misleading. What I actually meant was "Truck shifts gears without clutch while not running, it didn't used to do this..." If my truck was in gear I had to depress the clutch to get it out've gear, that is not the case now.
  6. Oct 28, 2014 at 8:48 PM
    Indy
    Indy Master of all I survey.
    Ive never had issues changing gears on a dead truck, as long as its not on a hill.
  7. Oct 29, 2014 at 6:56 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    its pretty common esp in bikes.. http://www.gravesport.com/Dynojet-Quickshifter-Sensor.html although its cutting fuel for such a small time its not the same as letting off the throttle imho
  8. Oct 29, 2014 at 10:01 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I wouldn't recommend it, it will ruin your synchros in a hurry doing that. Unless you have a transmission that is designed for it like a semi tractor-trailer, I wouldn't do it.
  9. Oct 30, 2014 at 1:14 PM
    hc243102
    ohio
    97 tacoma
    OK well we've all established that shifting gears while the truck is running is a bad thing (should be common knowledge). To be clear I have never or would never attempt this unless the truck is not running. Moving on I think something is up with my slave pushrod. It seems to be somewhat extended ( I can see part of pushrod sticking outve the boot) when resting so I'll continue on my quest.
