Shifting hard?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mxer256, Mar 19, 2013.
  1. Mar 19, 2013 at 4:56 PM
    Mxer256
    Mxer256 [OP] Well-Known Member
    Tyler
    Mississippi
    2012 Prerunner
    2012 Tacoma Trd sport, 10" bulletproof lift with traction bars and icon resi rear shocks, custom headlights and tail lights, 24x14 American force jades,37x13.50x24 Toyo mt, 1" borla wheel spacers, 30" lightbar, new build so more to come come
    I have recently changed spark plugs, oiled everything on driveshaft, I get my oil changed every 3k miles. I have 142xxx miles on the truck but lately it seems as if its just shifting hard. When im at red lights and have my foot on the brake as soon as i take my foot off it jerks. Has anyone ever had this issue?
  2. Mar 19, 2013 at 5:19 PM
    Taylor
    Taylor Wants to learn all about his Taco.
    Taylor
    Lynchburg/Harrisonburg Virginia
    03 4x4 TRD SR5 College build
    Extra badges, painted skidplates, grey wire mod, Kenwood double-DIN headunit, pioneer amp, 12 inch MTX sub, playstation 2 under seat, Uniden CB with 5 foot Wilson 1000 antenna, deckplate mod, 4xinnovations sliders, diff breather mod, bilstein 5100s at all 4 corners, OME Dakar Leaves, BAMF BPV bracket, Wheelers greasable shackles,
    Are you sure it's not axle wrap? You're not shifting as soon as you let off the brake.
    Is it more of a soft "clunk" or thump?
  3. Mar 20, 2013 at 5:13 AM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    It's just more of a thump. It doesn't make any noises just jerks. And it could very well be axle wrap. What are signs of that?
  4. Mar 20, 2013 at 7:26 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    A thump......;)
    Sorry, had to say it. :D
    It's hard to say....but chances are, it could be axle wrap, or driveline slop, or it could be normal transmission thump.
    With truck in park, and transmission in Park.... Crawl underneath and grab the rear driveshaft. Rotate it.... How much play is there? The more play there is, the more slop you have and this can give you a thump.
    Axle wrap has to do with the suspension being under load while you're on the brakes....and 'coming to rest' when you get off the brakes. This will depend on how fast you came to a stop (more or less - while trying to explain it).
    Transmission thump.... is something even 2nd gen trucks get..... but normally you'll feel the clunk after you've come to a complete stop with foot still on the brakes. It's a 'late' downshift (more or less). Again, the harder / faster you come to a stop....the more often (or harder) the clunk will be.
  5. Mar 20, 2013 at 2:44 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    No its more of when im at a stop and go to take my foot off the brake to go again. and sometimes when im just normally driving and its shifts gears. I will look at the driveshaft when i get a chance. Thanks. And also my lift in the rear is a 2 inch block. How would i know if i have axle wrap for sure or not?
  6. Mar 20, 2013 at 5:48 PM
    Janster
    Jandy
    Lancaster, PA
    You're gonna get a lot more axle wrap with a 2" block installed than you would without them.
    Here's a video... Just to show you how the suspension can flex .
    http://m.youtube.com/#/watch?v=cMw7KVvisv8&desktop_uri=/watch?v=cMw7KVvisv8
  7. Mar 20, 2013 at 6:36 PM
    Troutbum18
    Troutbum18 Member
    Dylan
    Georgia
    2000 Prerunner
    None Yet!
    I believe I'm having this same problem. I don't have blocks in the back and don't seem to have any sagging. I saw they make helper springs. Got an amateur question here, but if it's transmission thump, how big of trouble is that to fix?
  8. Mar 20, 2013 at 7:24 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    I just got under my truck, the front driveshaft does have some play in it and where it connects to the transmission it clicked when i twisted it. It did have some play in it. How would i know if i for sure have axle wrap?
  9. Mar 20, 2013 at 7:25 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    Probably have to get a new transmission. That would be my guess but maybe somebody that knows could tell you.
  10. Mar 20, 2013 at 8:30 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    When you say "shifting hard" do you mean just the axle wrap "thunk" or is it shifting hard thru out the shift points ??
  11. Mar 20, 2013 at 9:27 PM
    Janster
    Jandy
    Lancaster, PA
    When was the last time you had the transmission serviced /oil Change /flush?
  12. Mar 20, 2013 at 9:33 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Bingo !! This is where i was going... OP if you haven't serviced your trans I emplore you to do so ASAP !! I had just a couple of unusually hard upshifts the night before my trans had a major melt down & trust me you don't want to spend the $$$$ for rebuild (I was quoted up to $3400.00, thats $1.00 per cubic cc..)
  13. Mar 21, 2013 at 5:45 AM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    hey im rebuilding my trans now, i will pay no where near that much to have it done. even if my labor hours were 100 per hour.
  14. Mar 21, 2013 at 7:12 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Well then you'll save a shitload of $$$$....... :)notsure:)
  15. Mar 21, 2013 at 2:49 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    I bought the truck with 123xxx miles and it has 142xxx now. From the time i have had it i havent done it. And i dont know if it got changed before me or not. But also my dad thinks by it having this many miles it could be bad to change the transmission fluid. Ive heard several people say that?
  16. Mar 21, 2013 at 2:53 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    How can i tell if it needs to be changed?
  17. Mar 21, 2013 at 4:03 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    and its right when its upshifting. depending on where my rpms are at. Sometimes it doesnt shift hard and sometimes it does. But only when it up shifts i believe
  18. Mar 21, 2013 at 4:21 PM
    Janster
    Jandy
    Lancaster, PA
    Well... It could be bad if you don't change it.
    Does it have a transmission dipstick? Take a look at it. What's the oil look like or smell like? Is there enough oil?
    Also, have you checked for any diagnostic codes? Even though the CEL isn't on, doesn't necessarily mean there aren't any codes stored on the computer. There are critical sensors that, if failing, can cause the tranny to shift inconsistantly.
  19. Mar 21, 2013 at 4:22 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    The trans flush is a regular maintenance thing & I've had auto trans before that I NEVER flushed & never had a problem, but for whatever reason these A340F (if 4wd) really require the maint. & I wouldn't put it off AT ALL !! I did & mine smoked seemingly over night, nothing dramatic it just quit...& upon inspection I dropped the pan & there was like half a pound of metal
  20. Mar 21, 2013 at 4:52 PM
    Taylor
    Taylor
    You can check it by pulling your transmission fluid dipstick out. It's the orange one to the left of your block.
    If the fluid is brownish-black, you've burnt your transmission fluid, which is very bad.
    If it's a vibrant red, then you're a-okay!
    Check it while your truck is running, unlike engine oil.
