Shifting In SMode
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gas14081, Sep 24, 2024.
  1. Sep 24, 2024 at 4:39 PM
    Gas14081
    Gas14081 [OP] New Member
    2021 TRD Sport
    Bug deflector
    Hey there, just traded in a 15 TundraTRD offroad, for 21 Tacoma TRD Sport. Gas is expensive and I wanted something easier to hit the backroads in time.
    My question is how to shift in S-Mode?
    Ive never used S-Mode in the Tundra but figured I'd give it a try in the tacoma.
    I haul a utility trailer and sometimes a boat but it seemed the 20 tacoma struggled while in automatic.
    Is S-Mode shifting similar to shifting as if the truck had a clutch?, ex: slacking off on gas than shifting up into the next gear at appropriate RPM than adding Gas?
    I've been just going by the engine sound to get the right timing as it seems the shift intervals are not evenly spaced.
    Any help would be appreciated.
    Thanks.
  2. Sep 24, 2024 at 5:26 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    S-mode sets an upper limit, does not lock you into any single gear. I use S-mode for 4-HI to limit maximum speed ... sometimes S2, sometimes S3 ... trying to brake too fast on dirt can be dangerous.
    S4 is good for towing. Towing needs high revs to maintain top torque. D lefts it shift into 5/6 which is too low in revs, so S4 limits transmission to gear 4.
    SH10151, Chew and usmc2msu like this.
  3. Sep 24, 2024 at 5:57 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Welcome!
    S mode just limits upshifts to whatever gear number you have it in, and allows you to manually downshift to engine brake.
    Note: the Tacoma's 6 speed automatic's 5th and 6th gear are both overdrives, so if towing a significant load, it is wise to leave it in S4 as not to create excessive heat from torque converter unlocking and repeated shifting.
    While I great truck, the Tacoma's strengths are not in the heavy towing space.
  4. Sep 24, 2024 at 6:25 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I just use it for engine braking in the mountains.
    71tattooguy and MGMDesertTaco like this.
  5. Sep 24, 2024 at 6:56 PM
    Radd
    Radd Well-Known Member
    Santa Cruz Ca
    2023 Tacoma TRD Offroad
    I use S mode, often shifting in mountain twisties when towing and I just used it constantly when in 4 low shifting down to control speeds in both steep climbs and descents during an all day off road park clinic.
  6. Sep 24, 2024 at 7:05 PM
    assist
    assist Roadside Assistance
    New Hampshire
    2022 Silver TRD S 4X4
    I drive around in S4 80% of the time. S2 if im downtown for some reason, S3 for this one hilly road to keep the RPMs where I want them, S5 if im really cruising on the highway. D, S1, S6 do not get used.
    I hate gear hunting and I hate lugging my engine, therefore I love S mode :thumbsup:
    (I have OTT tune and do not tow)
    Ngneer, vaca, kahanabob and 3 others like this.
  7. Sep 24, 2024 at 7:44 PM
    JHK
    JHK Active Member
    2023 Toyota Tacoma OR DCLB
    Stock
    I also drive in S-mode. S4 for anything below 50mph. S5 for anything below 70. Truck drives so much better keeping the rpm’s between 1800-2100.
  8. Sep 24, 2024 at 8:09 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Yup, S-Mode is great to keep the upshifting to 5th/6th gear.
    I have the OTT Tune In Mild Drive/Spicy ECT.
    So much more torque without using S-Mode in ECT.
    On straight-aways, I'll engage 4H for monthly usage in ECT mode.
    One of the best upgrades I've done to my Sport. :)
  9. Sep 25, 2024 at 2:16 AM
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    You don't need to shift from S4 when you stop.
  10. Sep 25, 2024 at 4:35 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I swear in one of car care nuts videos he mentions not to use transmission for engine braking and not to shift like a manual with these automatics. Another thing he mentions is not to shift to park if your stopped 10 min or less. Use the parking brake .
    So a few things , Im at over 248k miles and I've done everyone of these things. Im the og owner 2017 and I have not suffered any issues . But thats me. I do use my park brake if I'm getting food at drive through and still leave it in drive .
    soundman98 and TacoTime55 like this.
  11. Sep 25, 2024 at 5:39 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I really have no significant mileage or knowledge to back it up, but I agree! My theory; brakes are cheaper than transmission and driveline wear, and designed for braking.
    I do use S1 to keep a slow roll before going downhill at the gun range, but don't downshift while moving often.
  12. Sep 25, 2024 at 6:00 AM
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    Yes and no. Flatland driving there's really no need to use engine/transmission braking, but in the mountains its needed, especially while towing. Using your brakes alone to control speed while descending down a +8% grade for 7 miles will cook your brakes and can lead to failure, so instead put it in S4 or S3 (depends on speeds) to help control speed and only use brakes for short presses.
    shotgunbilly420 likes this.
  13. Sep 25, 2024 at 6:01 AM
    rbdudeman
    rbdudeman Well-Known Member
    Not using transmission for braking...so going down a long - steep grade smoking the brakes / boiling the brake fluid to the point of 'brake fade' is better for the long term, but what about the short term?...I ask because I've been there.
  14. Sep 25, 2024 at 7:37 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Good points to consider...
    I don't use transmission for engine braking...I leave it in Drive. When in initial S-Mode (S-4), I bump it to S-5 above 55mph...although, not frequently.
    Not often, I put it in Neutral with parking brake engaged if stopped for less than 5 minutes...but again, not often and not a habit.
  15. Sep 25, 2024 at 7:46 AM
    mungusorungus
    mungusorungus Member
    Philip
    2023 Tacoma DCLB Offroad
    Snugtop, Warn M8000 winch, Warn semi hidden bumper, ARB onboard air compressor w/tank, Iceco reefer/freezer, 8 gallon pressurized water, Hottap water heater and shower.
    I use s mode most of the time. Speedometer goes to 140. I have had it at 110. 6th gear is for Wyoming flatland 95+ mph, 5th gear is for Montana rolling hills and flatland 80+ mph. less than 80 is 4th gear at 3000 rpms which is low rev. You can downshift when it hits 2000 rpm. Nobody should rely only on transmission for braking. Combine brake usage with downshifts. The dash control says I get 20 mpg average on long distance drives from Arizona to North Montana.
    Ngneer likes this.
  16. Sep 25, 2024 at 7:49 AM
    Radd
    Santa Cruz Ca
    I pull a travel trailer and do off-road without the trailer and down shifting in S mode for me is mandatory in steep descents in both off-road and pulling the trailer.
    Ngneer likes this.
  17. Sep 25, 2024 at 7:49 AM
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    I use S4 almost exclusively, always use ECT, and rarely drive above 50 m.p.h. and if I do I use S5 my truck never sees drive and I average 24+ m.p.g. in N.W. PA. with rolling hills.
    Ngneer likes this.
  18. Sep 25, 2024 at 8:55 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    So from what I gather here, ( i love this freakin site ).... is you can run in S4 from the get-go all day long not just
    use it when towing. If you find a stretch where you're hitting 50+ move her on up to S5 and enjoy the ride. ?....
    I know some folks run ECT all the time in 'D'.... any reason not to run ECT and S4 from the get-go?
  19. Sep 25, 2024 at 9:08 AM
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    Not trying to cause any :crapstorm: session, but for those that say you keep it in D and don't do / use any engine braking, you do know that you are still using engine braking. Just not to the elevated amount when going down into gear 3 or 2 or whatever. What do you think happens when you are at 70+ mph and let off the gas? You're not in N.
    Otherwise, yes. I also use S mode most of the time and select my max gear to the situation for the best driving experience. Even S1 on my steep uphill gravel driveway... more for the fun of it.:burnrubber:
    TacoTime55 likes this.
  20. Sep 25, 2024 at 9:14 AM
    Archimedes
    23 DCSB TRD OR MGM
    I am mostly in this camp. S mode, and ECT especially in town stop and go type situations so it's not hunting around too much when trying to drive around slowly right at the non-ECT shift points. Very annoying... highly recommended to play around and set to your likings. Nothing to hurt here.
    Ngneer and Vmax540[QUOTED] like this.
